Yepper.I wasn't ready for the clay.
Id like to see more water on the track.But I know they run the karts and 600 minisprints and Im sure they wouldnt like a wet track lol.Im looking forward to the18th .
250r rules
Im gonna try to make it out the 18th. I haven't been to paradise yet, it looks like a fun track although I'm not a fan of high speed turns like the one they have.
Im going Saturday to buy another pipe. Guy has it listed as oem .I believe its a Bassani. 85-86 250r. I have my other Bassani on my 85 250r with 67 mill bore,stock porting ,rad valve ,reed spacer,38 mill keihin from 91 cr 250. It rips pretty good. Has a wild power band.Im running 14/37 gearing with 18 inch rear tires.
250r rules
Is that a bassani? 2nd gen 200x?
Yes on both. The 200x is 86 its rough looking but has good compression,forks and shock are good,all bearings and bushings are tight,nothing is leaking,front brakes work,tires hold air.Seat front fender is broke,rear fender is missing,seat cover is shot,kickstart is hackjob.Going to try and start it tommorow.
250r rules
Got the 86 200x running.Carb was like brand new inside except the float was upside down.All 6 gears work.Front brake works very well.I think I will fix it up for a trail rider.
250r rules
Well your R got a good start off the line last race.
