Page 7 of 16 FirstFirst ... 5 6 7 8 9 ... LastLast
Results 91 to 105 of 237
Thread: 350X 400EX Transplant Build!
  1. #91
    Freedom Township, MI
    641
    Hmm..... Any possibly way you could shim the plate away from the triple??? What about using long studs instead of bolts for the handlebar clamps, then using spacers on the studs to shim the plate away?
    I'm going to keep that as a backup but I ended up changing the design to put the components on top instead. Check it out, I actually made 2. Which do you guys like better? Honda 350x or Honda wing?
    Sent from my SM-G930V using Tapatalk
    Current Trikes:
    85 350x
    P3 (x2)
    Quads:
    2003 Polaris Predator 500
    1988 Yamaha Warrior
    2003 Polaris Predator 90
    Previous Trikes:
    84 Honda 110 (parts)
    85 Honda 110
    85 Honda 200x
    87 Honda 200x
    85 Honda 250sx
    KX 80 Trike conversion
    Gone and missed:
  2. #92
    Slidell, LA
    4,737
    Honda wing
  3. #93
    Feb 2013
    Walford, Iowa
    120
    I think both look great. You couldn't go wrong with either one. Are you going to polish it or powdercoat it some color? Polished would add an element of bling to the build.
    Trikes Owned:
    1983 Honda 200x - Durablue Axle
    1986 Honda 250r - +2 westcoast
    1984 Honda ATC 70 - Piranha 140 swap
    1983 Honda 200e - Stepdads
  4. #94
    Dec 2003
    australia
    838
    Either design, but I think you should throw a white, red, or blue sandwich plate under it to bring out the design. It's getting lost because you can see the bars and gaps through the cutouts
    Sent from my iPad using Tapatalk
    My toys 85 KXT250A2, 85 ATC250R, 85 Tri-z 250, 06 LT-R450, 04 YFZ450S, 07 125 typhoon x 3, 06 FPV GT.
  5. #95
    JacobMonster's Avatar
    JacobMonster is offline At The Back Of The Pack Arm chair racerFirst time rider
    May 2015
    Liberty, Ky
    232
    I think Honda wing, especially since you have the 400 in there, it's "not a 350x" anymore. I like Quads idea. Putting something under the design would bring it out a lot more. Maybe some red LEDS? 😎
    Sent from my SAMSUNG-SM-G530AZ using Tapatalk
  6. #96
    Blossvale NY
    4,567
    My knee-jerk reaction was that I liked the 350x design just a little better, but Jacob brings up a very good point, not exactly a 350x any more...
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 200ES Big Red
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
  7. #97
    TTown, Alabama, United States
    845
    That honda wing would look good with the red white and blue behind it!
    Suicide Hill Survivor
    The rides:
    1981 ATC110
    1982 ATC185
    1983 ATC185s
    1984 ATC200es
    1985 ATC200x
    When the going gets tough, the tough get sideways
  8. #98
    641
    Ok, Honda wing it is. I'll circle back around to adding some color to it, I'm trying to get it running and then will come the beautification. No progress the past 2 nights as my dirt bike was stolen from my barn Low life thieves, hope they catch a handlebar through the chest. Yesterday was spent putting up some security measures.
    Current Trikes:
    85 350x
    P3 (x2)
    Quads:
    1988 Yamaha Warrior
    Previous Trikes:
    85 Honda 110
    85 Honda 200x
    87 Honda 200x
    85 Honda 250sx
    Gone and missed:
  9. #99
    Slidell, LA
    4,737
    Quote Originally Posted by Matt85'350x View Post
    Or a gas cap to the nuts repeatedly.....absolutely despise thieves.
  10. #100
    Blossvale NY
    4,567
    Thank God they didn't take the trike, especially after all of the work you have put into it! Effing thieves!
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
  11. #101
    641
    Not terribly proud of what I built today. Functionality test, I've got another air box if I want to revisit it. I cut the air box and cut a piece of aluminum for the back. Then made some brackets and riveted the back panel on. A little caulk will fill in the gaps. The idea is to trim down the intake tube so I can still put my K&N filter on. My filter is kind of a pancake style so it doesn't stick out very far. I'll be running no lid but with the other sides protected I'll still feel comfortable about going through puddles.
    Current Trikes:
    85 350x
    P3 (x2)
    Quads:
    1988 Yamaha Warrior
    Previous Trikes:
    85 Honda 110
    85 Honda 200x
    87 Honda 200x
    85 Honda 250sx
    Gone and missed:
  12. #102
    Manheim, PA
    5,754
    I am glad to see this did not turn into another cram it in trike. Keep taking your time and do it right and nice the 1st time. That little tube off your air box I use to just have a peice of metal cut then plug up the hole. They use to sell them on ebay for the 400ex's when they were the bike to have. Ill check back later and see how your doing on this!
  13. #103
    641
    Motor Mount DWG's
    I've got a few requests to share my motor mount drawings. I have them in DWG file format, anyone have a suggestion on how to upload them? The regular way said the file type was invalid.
    Current Trikes:
    85 350x
    P3 (x2)
    Quads:
    1988 Yamaha Warrior
    Previous Trikes:
    85 Honda 110
    85 Honda 200x
    87 Honda 200x
    85 Honda 250sx
    Gone and missed:
  14. #104
    641
    I'm also going a different way with the oil tank. I spent a lot of time and effort on the previous design but I'm not happy with the airbox and I'm not willing to go without it. My current idea is to integrate the oil tank into the gas tank. This will put the oil in an ideal location in proximity to the engine and oil cooler plus the tank is already rubber mounted! My original thought was an all new aluminum gas tank and having the oil tank worked into there but that's way too expensive. So what I've done is bought a nice OEM tank (at least the inside anyway) and I've contacted a builder who's willing to help me integrate the oil tank into the gas tank. I was looking at my P3 tank when I came up with the idea and then upon further research it's not so uncommon in the chopper world. Yes I know the P3 oil tank is for the injection; but the idea is still there-one tank with separate compartments. I don't have the tank yet but my initial thought is to extend the one side of it opposite the oil cooler to make it larger to hold the oil. I want to lose as little gas capacity as possible; the oil needs to hold 2 quarts. The scoop should basically hide the modification and there will be an internal divider to keep the oil and gas separate. There will of course be a separate fill cap but I don't think it'll look bad. Tank should be here tomorrow and the weld bungs should be here on Tuesday. Once the tank gets here I'll do some visualizing to see how I want it done, then I'll go over it with the builder to see if he has any input. At that point the tank and fittings get sent off to let the magic begin.
    Current Trikes:
    85 350x
    P3 (x2)
    Quads:
    1988 Yamaha Warrior
    Previous Trikes:
    85 Honda 110
    85 Honda 200x
    87 Honda 200x
    85 Honda 250sx
    Gone and missed:
  15. #105
    devore,ca
    1,015
    What are you using to view the DWG file ?. I can convert a DWG to a PDF if you send me the file. Anyone should be able to read a PDF file.
    YAMAHA 450 HYBRID
    85 350X- RED
    85 350x -BLACK
    86 350x-WHITE (with Goki)
    85 250r
    83 atc 70
    84 atc 70
    84 atc 110
    09 yfz 450
    2006 Arctic Cat Prowler
    RZR XP 900
