Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 37
Thread: Handlebar Vibration
    250ES5984's Avatar
    250ES5984 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Oct 2011
    Alabama
    199
    Handlebar Vibration
    Any idea how to fix the handlebar vibration on a 86 200x? I thought I had posted this before, but can't find the post.
    The vibration in my bars is getting next to impossible to stand anymore. Any help is appreciated.
    Thanks, Chandler.
    1986 Honda 200x
    1985 Honda 250sx
    FOR SALE
    May 2015
    Watford city, North Dakota United States "THE BAKKEN" / Lebanon, Oregon United states.
    1,081
    I read somewhere that somebody put rubber damper/bushings in the handle bar mounts to get rid of the excess vibrations
    Sent from my SM-G935V using Tapatalk
    Saying "it's the trikes fault" is like saying "guns kill people"
    don't poke the bear... you'll get banned
    Mar 2013
    Central PA
    2,362
    I would find the source of the vibrations before anything. Loose exhaust bolts? Could be anything.
    I know of two strokes if you don't have the little rubber dampeners in between the fins it's really annoying.
    May 2009
    S.E. Michigan
    1,250
    Honda 4 strokes are usually pretty smooth. Have the vibrations always been there, or did something happen and then they started?
    - Frank
    1984 200ES Big Red
    1985 350X (x2)
    1986 350X
    1986 250SX
    1984 Auto-X
    1984 ATC70
    1985 ATC70
    Michigan UP
    1,005
    First off, don't laugh, it helps. Take one of your grips off, take a can of expanding insulating foam and spray it through from the other side. It's going to start coming out of the side with no grip, when it does, stop spraying and plug the little hole in the end of the grip still on the trike and wait for it to stop spewing out the other side. I did this to my yamaha grizzly 660 and it helped quite a bit.
    RUNMEDOWN is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2006
    Omaha Nebraska
    319
    Add weights to the inside of the bar or just add some bark busters, they will lock them down.
    85 ATC110 - The Greatest ATC of all time - (My First - new in 85)
    83 FL250 - Odyssey w/420cc - SOLD
    82 185s -10.25:1 piston, Full 200x upper, Goki Electric start - SOLD
    84 200x - Auto-X - Weisco Hi-comp, Cam'd, Bassani'd, Westcoast swinger, -SOLD
    82 200E Big Red -SOLD
    85 ATC250ES Big Red - Snow Plow !
    Slidell, LA
    4,737
    Quote Originally Posted by 250ES5984 View Post
    Thanks, Chandler.
    1986 Honda 200x
    1985 Honda 250sx
    FOR SALE
    Vibrations in 200x handlebars don't exist, first or second gen. If you think they do then never ride a CR 500. I would check to make sure everything is ok with your clamps and/or motor mounts.
    If you mean arm fatigue from riding then that's another discussion.
    Jul 2013
    USA
    738
    I bought the x new, still enjoy it. There never was a headstay bolt in the bracket because the holes didnt line up. I never inquired about that and had no problems or vibration.
    250ES5984's Avatar
    Oct 2011
    Alabama
    199
    I'm not sure exactly what's causing it. I'm sure I'll find out when I pull the motor. Just figured I'd ask before hand.
    1986 Honda 200x
    1985 Honda 250sx
    FOR SALE
    Mar 2007
    Texas
    5,046
    Handlebar Vibration
    When you say vibrating do you mean when riding over terrain that is rough, or when idling it makes your hands go numb? 2 completely different issues.
    If during riding you can get a flexx bars or dampers. If during idle you have a bigger problem. A 200x should not have that much vibration. You have something wrong with the engine.
    ________________
    https://www.mikesatvfix.com
    250ES5984's Avatar
    Oct 2011
    Alabama
    199
    Quote Originally Posted by oscarmayer View Post
    No, it's going over smooth terrain. Like down the road at around 3/4 throttle. Not even going to start on full throttle.
    Flexx bars have crossed my mind. Any idea as to what the OD of the bars are? I've honestly never had the need to know.
    1986 Honda 200x
    1985 Honda 250sx
    FOR SALE
    Mar 2007
    Texas
    5,046
    They make an adapter to mount them to a 7/8" bar which was stock on the old trikes. The flexx are 1.25" I believe.
    If your hands are going numb from that much vibration. The motor has issues internally. You need to look at a rebuild. Does it vibrate bad at idle and super slow speeds? If yes then it is in the crank area if no it is in either the trans or could be an axle or bearing back there. I would blast my 200x wot all the time with no issues. So it really sounds like you got other issues.
    ________________
    Miami,Fla.(305)
    808
    Flywheel issue possibly???- wobbly or loose??
    Previously Owned:
    1985 ATC 250R (261cc)- 38MM PWK QV/AS, VFORCE3, RPM TIMING ADV., FULL DG EXH, CLARKE WHITE TANK, DOUGLAS RED LABELS, PRM NERF BARS, + ALUM. PARTS
    1983 ATC 185S (186cc)- HI COMP., BASSANI HEADER, REAR DISC BRAKE CONV., '86 200X HUBS, ALUM. RIMS, DIRT DEVILS
    1982 ATC 185S (224cc)- PK WELD-ON KIT, PK CLAMPS, PK EXHAUST, SL90 SHOCKS, OIL COOLER, PCCC RIMS
    1981 ATC 185S
    1984 ATC 250R
    1981 ATC 250R
    1983 ATC 110
    1969 HONDA MINI TRAIL 50
    TRIKELESS
    Mexico
    9,010
    1-1/8"
    It sucks to get old
    250ES5984's Avatar
    Oct 2011
    Alabama
    199
    I definitely don't need bottom end problems because no one around here will split the cases, and I'm definitely not doing it myself.
    This is pullin on my nerves...
    1986 Honda 200x
    1985 Honda 250sx
    FOR SALE
