I'm having problems with my carb 34mm mikuni ,running a 225 main jet,40 air jet.at three quarters to full throttle it's starts to bog down loss of power.can anybody help.Thank you
First check your spark plug, is it wet carbon covered or dry white. That will tell you if it is to rich or lean. Check the float to see if it is stuck and flooding the cylinder or has a hole in it and starving the motor. Make sure you have no air leaks in the intake boot between the carb and the cylinder reeds. That is a start.
David (david@wrightracing.net)
Hay thanks for responding, my spark plug is black with some carbon ,a little wet, but not saturated. I adjusted my floats at 23mm. My in take doesn't have any cracks. I changed my reeds not new ones but with some good used ones.and for my needle I have it at the top slot. Question though , the vent on the crank case I got that going to the side of my carburetor is that good or not. Thank you let me know what you think.
My plug is black with some carbon, and a little wet not saturated.
First, the vent line on the carb and the case should not be connected. They need to vent to the open air. I have never seen that done on a 2 stroke and it could be causing a fuel to air mixture issue. For the float, if it is cycling properly and the float doesn't have any holes in it, it should be fine. Start off with a new spark plug, NGK B8ES or Better would be a BR8EV. The obvious things to clean like the air filter and fuel petcock filter can cause issues at open throttle.
David...
As for the needle, 3rd from the top would be a little rich at sea level, where I live in San Diego and our local desert. If you still have a problem after you fix the vent lines and a new spark plug. Then move the needle jet clip up one and try it out.
David...
