soaked one of my 200x carbs in cem dip put a rebuild kit in it and adjusted the plastic float to 14mm . It was at about 12 or 13mm I bent the plastic the best I could making it 14mm it's leaking from the over flow on the bowl like the float is to high or sticking. Though well maybe the cem dip ruined the valve seat so I put the same rebuild kit in a different carb cleaned with carb cleaner same problem? Just rebuilt the the top end and the bike runs really good has maybe an hour on it just need to fix the carb leaking any advice? Gas cap vent is working.
