Jets are just the screw in part.
One method, which most people condone, is the drilling the jet out method. If you cant find a new pilot jet, you may need to drill it out. You'll need a microdrill bit set ($7 off amazon.com). Find the biggest one that fits, then go 1 size up. If you go to large. Solder it back up and try again.
Once you locate the correct size bit, find a jet to match that if you can. If not, solder works fine. Never had an issue.
What is worn out on the old carb? There is only a few moving parts.
