Results 1 to 13 of 13
Thread: honda 200es speedometer cable fitment. from other trikes, bikes, atv's
    honda4h's Avatar
    honda4h is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    ottawa ontario
    361
    what other if any speedometer cables fit atc's? off other honda bikes, atv's etc or other brand ?Click image for larger version.
    Apr 2002
    s.w. michigan
    6,498
    What I look for is the shortest cable length,,,, interestingly enough seams to be the hardest information to glean from a ebay add or other sources.
    Out side the obvious end hook up, any length will work.
    The cable I'm using on my 84 250r fork set up is a wee bit too long and kinda loops outwards.
    I recall measuring my correct length 85 bigred 250es speedo cable @ 29 inchs. My buddy has just snapped her second cable so I to have been scouring ebay for the shortest length,,,, nothing yet.
    I still have the broken cable + housing from her first broken cable that is stock ( it came off a bigred I had sold) ,,,, . I can do plastic + rubber parts but when it comes to metal I am not any good.
    Anybody handy enough could have a small but nice "after market" buisness.
    Pic of my excess cable hanging out left side. Hopefully it shows,,,
    john
    Attached Thumbnails Attached Thumbnails 20161020_190353.jpg   20161020_190430.jpg
    Apr 2002
    s.w. michigan
    6,498
    First pic don't show it. 2nd. pic it's about 1/4 way down the left fork boot.
    Mar 2003
    Australia
    1,919
    I run a ct110 cable on my bigred. It's about an inch too long but works fine. There are two different cable lengths for the ct110 so get the shortest one you can find.
    Matt
    1980 ATC 70 Needs Restoration
    1985 ATC 250es Fully Refurbed
    1986 ATC 350x Mint Original
    Apr 2002
    s.w. michigan
    6,498
    Thanks Matt ! I just ordered this one for my buddy.
    john
    http://www.ebay.com/itm/Honda-SS50-C...nPLJ0g&vxp=mtr
    Mar 2003
    Australia
    1,919
    John Im sorry, I think I have given you a bum steer! The cable I used on my big red is a CT90 trail cable which measures in at 660mm long. I was mixed up as I used the CT110x cable on my 350x. Sorry mate. Also just noticed that the cable in the picture of the listing has the wrong end on it for the speedo gear drive!?
    Matt
    Apr 2002
    s.w. michigan
    6,498
    Lol,,, from your information I did find a couple,,,, one being correct end + other with incorrect end
    I put both in my ebay watch then next morning I hit the buy it now,,,, on wrong one
    Seller was real good about the return so all good. Correct one (or close enough and brand new and reasonable ~ 11 dollars or there abouts)
    Good info Matt !
    Mar 2003
    Australia
    1,919
    That's the way! Glad you got it sorted anyway John. Yeah the motion pro cable I bought have been good quality and at a fraction of the price of the OEM one you can't go wrong. Happy to help.
    Matt
    honda4h's Avatar
    ottawa ontario
    361
    what year of cable did you guys get for the ct90 i see different ones. and the ends do not look the same as the atc one but if it works i'm golden
    Apr 2002
    s.w. michigan
    6,498
    Mine came in today
    This will definitely work better then "the too long" broken motorcycle cable my buddy has.
    11 bucks, inch and a half longer then stock 250ES,,,,, perfect.
    Attached Thumbnails Attached Thumbnails 20161028_220501.jpg   20161028_220444.jpg   20161028_220131.jpg
    Apr 2002
    s.w. michigan
    6,498
    On the one I pictured above I put it on my buddys trike today. Install the drive gear end first and found the speedo drive end was 3/8ths. a inch too long to fit into speedo head properly.
    Dremal cut it off 3/8ths. and ~ perfect fitment
    honda4h's Avatar
    ottawa ontario
    361
    right on thank you sir for the info
    Mar 2003
    Australia
    1,919
    Good work John. Glad you got something that works!
    Matt.
