What are you using for a carb setup?
Chinese 250cc watercooled engine. about .5hp-1hp over the stock 200x. no mods available for it, but you can take the had off have it decked down a couple of thousandths to increase compression and that will bump you to 15-16hp stock instead of the 13.5hp. I have the 300cc version sitting on a shelf and been debating on doing something with it. good luck.
it will be a 1-off but the question is will it be worth it? only you can answer that. The CRF230F may have been a better choice due to it is a near bolt on and tons of support and also includes electric start. but you already got the motor so use it. worst is you run it for a few years then either sell the trike or swap the motor out.
have fun and enjoy! you may need to modify the mower engine mounts as they will probably not align up and hit the case.
________________
https://www.mikesatvfix.com
should be a 250cc. that is where the china started making water cooled. they go up to 500cc. I have the 300cc from TaoTao and an considering doing something with it.
________________
It was listed on ebay as 200cc. I thought it resembles the 250 as well. The engine is a 169ML, and not a whole lot of info about it on the net. Also comes up as a CG 200. Bummer is no kick start option.
I'll have to make a trip up to you X and see that build
Sent from my SM-G935V using Tapatalk
Saying "it's the trikes fault" is like saying "guns kill people"
don't poke the bear... you'll get banned
Gotta get to the dunes!!!
Motor mounts complete. Took some pics of the ones I had to modify. I got my exhaust mounted. I had to add a little spacer because of my bent grab bar. I went ahead and ordered a 30mm carb off ebay, and I also ordered the kx 100 radiator and give it a shot. Getting closer, I still need to order a wiring harness, and I was not sure if any of the stuff off the stocker will work, or should I just order the whole kit.
Only guessing but looks like some sort of an EGR. Exhaust Gas Reciculation or maybe for an O2 sensor(?)
Cap it off
EGR relief that is not needed. Make a cover and cap it, or take head off and tap hole then put a plug in it(perfected method). If you do the plug you can even thread it in to the point you can make it flush in the exhaust port so it does. It interfere with exhaust flow having a hole in the middle.
________________
________________
