Just Too Addicted
Arm chair racerJust too addicted
Apr 2014
Australia
580
1984 atc250r chain slider
Hey guys my atc250r hasn't got a chain slider and the guy I brought it from has just glued in rubber! I looked on eBay and they have an aftermarket one. Has anyone used one are they good? Also there is a small bracket that Iam missing to bolt up this chain slider! Has anyone got a picture of what the bracket looks like or is it possible to make one?
Below is the chain slider from eBay
Sorry about all the posts, new to the trike, all help is greatly appreciated!
Thanks Ivan
P3 Member ( RIP 8/15/2018 )
The day begins with 3WW
Apr 2002
s.w. michigan
6,500
Not a whole lot to that small metal piece that holds it into place really. I don't have one to show but mainly the ends are bent inwards on both ends + fit into the slots on the oem slider. Bolt hole in middle is the only thing holding in place.
My wife also makes those in oem olive drab color, just like original but shipping may off set part cost vs. the one shown in your link.
Nice thing is you don't need to take the swing arm bolt out to install like other ATC Honda models.
Just Too Addicted
Apr 2014
Australia
580
Thanks jeswinehart! So the only thing I need to do is put on the chain slider and bolt it to the side of the swingarm? Is there any bolt holes on top on the swing arm that are countersunk that the chain slider is bolted into the top of swingarm?
Thanks! Yes at least I won't need to take the swingarm bolt apart
Apr 2002
s.w. michigan
6,500
It is one bolt only. That bolt fits into side of Swing arm and also goes thru the slider at same time.
Since we have a box of them I will get some detailed pictures of the bracket tab insert and bolt hole area if you'd like,,, tonight after work.
Apr 2002
s.w. michigan
6,500
Ivan, am I reading the ebay link correctly ??? It would cost you like 65 dollars (our dollars) for that slider shipped to you ???
Heck, pm me your address. I can do a lot better then that pricing (if I am reading it correctly ? )
