Page 2 of 2 FirstFirst 1 2
Results 16 to 29 of 29
Thread: My 85 250r winter restoration
    trikeguy2014's Avatar
    trikeguy2014 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Mar 2014
    Indiana
    158
    Yeah after talking with the guy we decided against a gloss black, being it's 30 years old he suggested to do closer to a satin black to hide imperfections in the parts.
    One of the Haspin Locals
    Trikefest 12' 13' 14' 15' 16' 17'
    Trikes owned
    1985 Honda atc 250r - raced by yours truly #27
    1985 Honda atc 250es big red- Dad bought new from Ike's Honda in Richmond Indiana
    1984 Honda atc 200s - raced by Evan Pflum #3
    Mar 2014
    Indiana
    158
    Updates from weekend one and two
    Got it back to a roller... still have to polish rear wheels
    New carrier with double row bearings
    Lonestar +4 axle
    New brake stay
    EBC pads
    Swing arm bearings from pivot works
    All balls stem bearings and races
    All balls front caliper rebuild
    All balls front wheel bearings
    Stainless stream line front brake line
    Nearly every bolt has been replaced with the stainless equivalent
    Honda Genuine rear brake reservoir
    eBay I found good set of pegs I got powdered
    eBay I found a decent over flow bottle and cap as well
    Trikes owned
    Snohomish, Wa
    1,028
    Dam! That thing is coming along nicely. Good job. Have you decided what your doing motor wise yet?
    85 ATC 250r -Under Construction
    86 TRX250r
    05 KFX400
    02 400EX
    Oct 2013
    New Hampshire
    77
    Looking good, how did your wheel hubs fit the new lsr, I'm sending one back becouse they wobbled didn't fit snug, lsr say they should be snug and will replace it.
    NEPA
    7,048
    Looks to be Arctic Cat ZR caliper if you ever need pads.
    Mar 2014
    Indiana
    158
    Quote Originally Posted by roll on 3 View Post
    No problems hubs fit like they should
    Trikes owned
    Mar 2014
    Indiana
    158
    Not sure what caliper came off of, but it uses Trx 250r front pads
    Trikes owned
    Mar 2014
    Indiana
    158
    Quote Originally Posted by 250rmanfmf View Post
    Still haven't decided, going to work on polishing cases, might do an esr bolt on kit to go to a better carb and reed setup they come with
    If not will probably just do top end fresh up and stick with what I have.
    Trikes owned
    Mar 2014
    Indiana
    158
    Small update since I haven't posted in awhile
    Got radiators installed
    wiring harness cleaned up and put back on
    brakes bled
    Stator cover stripped and polished
    Trikes owned
    The Open Road
    4,729
    Nice work!
    Mar 2014
    Indiana
    158
    Back to running and nearly finished, but I couldn't wait any longer... still need to wet sand and polish rear plastic, and few other little things
    Engine ended up getting new piston, bored and ports chamfered. Center cases were painted, covers were polished, and cylinder and head were powder coated
    Trikes owned
    Freedom Township, MI
    641
    Looks great!
    Sent from my SM-G930V using Tapatalk
    Current Trikes:
    85 350x
    P3 (x2)
    Quads:
    2003 Polaris Predator 500
    1988 Yamaha Warrior
    2003 Polaris Predator 90
    Previous Trikes:
    84 Honda 110 (parts)
    85 Honda 110
    85 Honda 200x
    87 Honda 200x
    85 Honda 250sx
    KX 80 Trike conversion
    Gone and missed:
    Sep 2008
    Buffalo
    808
    Well done I can't wait to re-do my 250r one day
    Tpc 450
    86 250r
    86 350x
    86 200x
    86 250sx
    85 225DR
    (2) 84 YTM
    (3) 85 Atc 70
    9,012
    Gorgeous!!!
