I used the clutch parts from the cyclone on this. I ended up having to basically build 1 clutch from all of the extra drive pulleys I had laying around. The belt I used was a Gates G-force belt. I took it for a test run last night and the clutch was working pretty good. I can't do much else until my air filter comes in and I get the air box fully installed.
On a side note. I swapped the rear axle for one from a 400. Its an inch wider overall and you can use the aluminum hubs from the later style Polaris's.
Sent from my SM-G900P using Tapatalk
