The fender rubs the cylinder head when i turn the forks.
If the fender is mounted correctly then something definitely isn't right. It looks to me like the forks are bent in the last picture you posted.
Trikes Owned:
1983 Honda 200x - Durablue Axle
1986 Honda 250r - +2 westcoast
1984 Honda ATC 70 - Piranha 140 swap
1983 Honda 200e - Stepdads
The forks dont look bent either.
I found a pull start in the tub of parts along with the carb and flywheel.
Chances are it is your neck. There is a thread on here about straightening them out with a bottle jack. Just be careful not to go too far.
R.I.P. John Swinehart
Epic Mikfest 17
86 200x
85 250sx
85 big red
85 atc 70
If everything looks straight to my eyes then how do I know how far to bend the frame? Surely Im not supposed to base it on just the distance between the fender and engine?
The top tube should be straight. Put a true edge on the backbone. It should lay flat if not it's bent. Adjust accordingly.
Above your coil I spot a hump.
Is this the one you're refering to, weezy? The detailed instructions for straightening a frame are at post #11
http://www.3wheelerworld.com/showthr...t=atc+70+frame
Having a pull start is a plus! As Evan said, something is not right as I can see marks on the front fender. Get out a straightedge and check the backbone and the forks to make sure.
Trikes
1970/71 US 90 (Aquarius Blue)
1972/73 US 90 Green
1977 ATC 90 w/83 110 motor (Fugly)
1982 ATC 70
1983 ATC 70 (Ladybug)
1973 ATC 70
TF 2015
Other
1983 Honda Z50
1978 Honda XL75
Get a gasket. Your at the party u mine ad well have a drink.
