If you tilt the carb, the float may not work right. Seems like it would cause problems being tilted to one side, it may not fill properly?
A little heat and a ball peen would massage that tank to fit your needs
Can anyone tell me if the rear fenders sit directly on the metal mounting bracket or is there a piece of rubber that goes between the fenders and the frame?
I think the 70 fenders sit right on the frame, I done recall seeing any rubber pads on mine when I took it off the other day.
Yeah man, that woodruff key looks too low. I can't see how that would grip the stator keyway. Maybe you could machine a taller one?
Very cool, nice work!
I just took it for a test ride. As soon as I put it in gear it started leaking a LOT of oil where the front sprocket shaft goes into the high-lo range box. Is there just a seal there or is it likely I have bigger problems? It does not leak when it is idling in neutral
I am curious about this project. What did you find was the transmission problem when you were unable to shift gears? I ask as I have a similar issue with my TRC70 project.
Thanks
