Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 42
Thread: Rebuilding 200x After 6yrs
    rodeofan5656's Avatar
    rodeofan5656 is offline Girlfriend wishes I'd last longer than 8 seconds Arm chair racerAt the back of the pack
    Dec 2011
    Park City, KS
    389
    So i warn you now, i have alot of 200x questions.
    This will be kind of a "duplicate" thread, as i didnt seem to have access to the Trikesylvania section until after the first thread in the New Members section...... http://www.3wheelerworld.com/showthr...-ATX200X-Build
    1986 ATC200X- Ive been away for awhile. But I finally got the engine out and the top end apart. Found alotta slop in the piston with wear marks on the piston skirting and cylinder walls. Which explains the excessive oil burning and exhaust smoke. Ive got a few questions about this build, with hopes that someone can help me out.
    1) i plan to go with a Wiseco piston, 10.25:1. Ive been told the 12:1 is known for destroying transmissions (?). JSR Performance of Wichita, KS can do the bore job for $45. Fair?
    2) the camshaft, chain, and guides look alright, except for a shallow groove worn into the front side (non-tensioner) guide. Is the guide still ok to use? What should be replaced? Also, the rockers has some visible wear, on camshaft ends, you can feel with your fingertips. Should these be replaced? And where to buy?
    3) bent rear axle and rigged axle bearing carrier I read awhile back about a 300ex swingarm swap, but cant find anything anymore. Can someone point me in the right direction? Or have any access to an axle and/or carrier?
    4) cosmetics- i have a cut up atc110 front fender right now, and it looks terrible. No rear plastics. I also heard 300ex rear plastics will work with slight modification. Where can i find this info? And also, something about an old 250r front fender fits the 200x?
    Thanks for any info you have! Glad to be back.
    UPDATE: The shop has the cylinder now. They are boring the cylinder, ordering me a Wiseco 65.5mm 10.25:1 piston kit, and full engine gasket and seal kits all for $220 before tax. I highly recommend JSR Performance of Wichita, KS to anyone needing parts and service!
    They will have my rockers hard welded later, and are full of information!
    1986 Honda ATC200X
    2005 Yamaha Road Star 1700
    ToyHauler- 1998 Ram 3500 5.9L Turbo Diesel
    Dec 2011
    Park City, KS
    389
    In the pictures, you can see the inside of the engine casing is cleaner than the outside! Also, you can kinda see the wear of the cam and rockers.
    Another question- on the stator coils, 2 look to be coated. Is this normal?
ID:	237890Click image for larger version.
ID:	237891Click image for larger version.
ID:	237892Click image for larger version.
    1986 Honda ATC200X
    Aug 2016
    East of Worcester ma
    1,328
    Hello, well it sounds like your heading in the right direction. You can probably get away w/not replacing the cam chain guides if there not to worn or dry rotted (lots of small cracks) but i'd definetly do the chain. Its a 100 link 25h-chain http://ebay.to/2hkPLUq its pretty cheap insurance.
    Make sure to grab a engine seal kit too while your at it, the upper decomp seal is discontinued and doesn't come with
    The kit you can buy on ebay. I bought a bag of thirty of them (just decomp seal) if u end up going that route let me know.
    No charge.
    Make sure your machinist orders 86/87 piston not 83/85 theres a difference im just not sure what?(anyone)?
    The cam and rockers well you'll figure that out $$$. Search 86/88 trx200-- and fatcat you may come across a nice used set.
    There's definetly more knowledgeable people here then me but i figured i'd put my 2-cents in...
    Yes its normal--Click image for larger version.
    Shep
    Jeez- grab some new valves too..(ha)
    Dec 2011
    Park City, KS
    389
    Idk if its the 200x, but i saw a build about a 1982 200cc and the piston crown was dished. Mine is more of a dome. But i specified pretty hard on the year, and watched him find the part number in the Wiseco catalog. If its incorrect, its all on him.
    Thanks for the stator picture, that makes me feel alittle better. At first i thought they were burnt
    1986 Honda ATC200X
    arlaunch's Avatar
    arlaunch is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2014
    Oregon City
    346
    1984 Honda Big Red ATC 200ES (Emma)
    1985 Honda 200X ATC (Pretty Boy)
    1985 Honda 250R ATC (Dr. Fast)
    1985 Honda 250R ATC ( 77 )
    1985 Honda 250R ATC (Baller)
    1986 Honda 350X ATC (Go Go Girl)
    Feed Back: http://www.3wheelerworld.com/showthr...k-for-arlaunch
    Dec 2011
    Park City, KS
    389
    So i tore into the head today. Valves could be reused, but guides are SHOT. So ill probably do new guides and valves. Can we still get guides for these things?
    Found what looks like grind marks from where someone tried to taper the intake port (?).
    Also found some good info about the 300ex carrier and axle conversion.
    Trying to get the forks out of the trees to have the lower tubes polished. Also gettin frame ready for paint. Not sure on a color yet But i dont think this will be a restoration. I think itll be a custom/rider. So itll be all personal. I like all black, but i want just alittle flashy. Cant quite find a color scheme i like
    1986 Honda ATC200X
    Aug 2016
    1,328
    I'm pretty sure all the intake ports were chamfered like that at honda Click image for larger version.
    To give you ideas here's my sons a few years agoClick image for larger version.
    Apr 2002
    s.w. michigan
    6,500
    Logan, I believe you may have forgotten this posting from a few years ago (?),,,, sounds like the TRX fenders are a fit with some mounting hole re-location.
    http://www.3wheelerworld.com/showthr...ers-on-86-200x
    When/if you get to the fender part of your rebuild and need some detailed pictures of my 2004 ( or 2006 ~ can't remember what year it is right now) TRX300EX fenders that I made into a trike by putting 83/84 250R front end on it,,, give me a shout.
    Dec 2011
    Park City, KS
    389
    Well crap, i completely forgot about that one. Its been so long, i googled the axle carrier and took me to an old thread i had posted years ago. I'll go back thru that one and see what i can figure out. But with the price of plastics these days, i might as well do the direct fit Maiers. I do like the round look of the EX fenders though
    1986 Honda ATC200X
    Dec 2011
    Park City, KS
    389
    I hate to start a new thread for each question, cause they keep piling up the further i get into this thing. Like that fact i need valve guides and these are all i found. Hopefully someone who has used them will take a gander at the thread and give me some input
    http://m.ebay.com/itm/Kibblewhite-Va...511?nav=SEARCH
    1986 Honda ATC200X
    Yes, Kibblewhite is good.
    Dec 2011
    Park City, KS
    389
    Thanks for the OK. I was startin to get worried. Got one of our Recon guys at work to do a polish job on the lower fork tubes. Itll cost quite a bit more than paint, but itll sure look better. So it may not be runnin quite yet, but itll look purdy!
    Id love to post all the pictures ive been taking. But uploading them as an attachment 1 at a time, gets old quick. Anyone know an easier way to add multiple pictures to a post?
    1986 Honda ATC200X
    Apr 2002
    s.w. michigan
    6,500
    Photobucket
    Dec 2011
    Park City, KS
    389
    I tried photobucket on my phone and it went crazy. Started opening tabs like pop ups, and wouldnt let me login without adding my Facebook info. I just didn't feel comfortable with it.
    1986 Honda ATC200X
    Dec 2011
    Park City, KS
    389
    Are all the steering bearings the same on all years of the 200x?
    Ive got the engine about 40-50% apart. From what i can see, all the gears and transmission parts are good. Is it recommended to tear the entine engine assembly apart and separate the case? Everything rotates smoothly. If no one thinks theres much reason to go any further, i may leave it. The only things i have left to remove are clutch assembly, and parts to access cam chain and guide.
    1986 Honda ATC200X
