Also what brand is that fromt rim?
22x8x10 sandstar front tire. 10 inch rim from Jonathan, not sure what his sign on is on here. I probably should go with a 7 inch wide front tire, but I think this one will work, ts just close. The caliper is very close to the rim, just touches it in a few spots, probably runout from the wheel. I'm going to grind about a 1/16 off the caliper where it touches.
Judging but what's hitting that shouldn't hurt anything , you might want to take some more for good measure.
Sweet setup thanks for the pics! What did you do for that front axle?
Sent from my SM-G900V using Tapatalk
Atc 500x for the win! (Hopefully.... one day)
86 250r axle and hub.
Yes, a couple fins need a very light amount of material to be removed.
I use a roto-loc sanding disc in my pneumatic die grinder.
Make sure whoever is building your swingarm sets it up for the right seat height. I've seen allot of conversions and some are too high; A lowering link helps as well.
You may also want to make up some brackets to move the footpegs a bit further forwards. Dirt bikes location is further back than the 3 wheeler likes to be...
