Results 1 to 15 of 62
Thread: 185s build (full suspension) - 2021 Update
    ZacH_GrifF's Avatar
    ZacH_GrifF is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jul 2011
    Pearl, MS
    405
    *Picked back up working on this thing for 2021 on post 34
    *For the rear suspension details go to page two. Ill be creating a new thread with the details of the swingarm swap later after I finish. This thread is a complete build thread of the whole bike.
    In the process of rebuilding my 83' 185s. Wouldn't call it a restoration because I'm deleting some stuff and modifying some stuff. As for the motor its pretty much already built but i don't have any pictures of it at the moment. It got upgraded to a 200s cylinder, shindy 10.25:1 piston, xr 200 cam, and new barrett clutches. Thanks to Ol Deuce for the adapter its got a 83 250r front end on it. I'm currently in school for civil engineering so I make progress on it when I can. There is a lot left to do on it but I'm just gonna take my time and build it how I want it so I thought I'd share my progress so far with yall.
    (picture with the white plastics is the day i bought it about 6 years ago)
    Attached Thumbnails Attached Thumbnails 11.jpg   9.jpg   8.jpg   7.jpg   6.jpg   5.jpg
    1. 83 185s: (the money pit) xr200 cam, 200cc cylinder, 10.25:1 piston, 83 250r front end, 450r hubs, full suspension
    2. 85 Big Red 250es: in pieces
    3. 85 200m
    4. 00 Polaris Magnum 325 2x4: stays broke
    5. 02 Yamaha Wolverine 350 4x4: trail bike
    Jun 2009
    Leander TX
    2,217
    Looks great.
    tough to find a seat pan for those.
    ZacH_GrifF's Avatar
    Jul 2011
    Pearl, MS
    405
    Thanks. Tell me about it haha. The one I have now is actually in great shape. Just a little surface rust on it. I got it from a guy on here for a good deal. The old one was in several pieces held together with duck tape.
    3. 85 200m
    axeman24 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2016
    long island NY
    247
    build looks great
    do you have any more info on the front end adapter ive got a 250sx (same tree as the other big bikes) front end id like to put on my 200s
    ZacH_GrifF's Avatar
    Jul 2011
    Pearl, MS
    405
    PM Ol Deuce he should be able to get you what you need.
    3. 85 200m
    Jun 2009
    Leander TX
    2,217
    Quote Originally Posted by ZacH_GrifF View Post
    Coat it with POR15 or something to preserve it. Metal seat pans tend to disappear as you know!
    ZacH_GrifF's Avatar
    Jul 2011
    Pearl, MS
    405
    Yea I think Ill just spray some undercoat on it. It's a budget build haha.
    3. 85 200m
    plevib's Avatar
    plevib is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Dec 2015
    North Dakota, USA
    358
    8 inches of front travel on a hard tail haha...... that'll be interesting nice work so far. Looks good
    Sent from my SM-G900V using Tapatalk
    Atc 500x for the win! (Hopefully.... one day)
    ZacH_GrifF's Avatar
    Jul 2011
    Pearl, MS
    405
    Little more progress, finally sourced all the 250r front end parts. Put new steering stem bearings in. Used a heat gun to get rid of the oxidation on the plastics. Usually comes out better but these are really sun dried. Gotta get 250r handlebars, didnt realize they were wider than the 185s bars. Keeping these big rear tires until I can decide what setup I want to run for a rear swing arm. Will use 20"s for the back then. Still gotta pop a dent out of the gas tank and paint it.
ID:	239880Click image for larger version.
ID:	239881Click image for larger version.
ID:	239882Click image for larger version.
ID:	239883Click image for larger version.
ID:	239884Click image for larger version.
ID:	239885Click image for larger version.
ID:	239886Click image for larger version.
    3. 85 200m
    ZacH_GrifF's Avatar
    Jul 2011
    Pearl, MS
    405
    Looking to buy an exhaust for the 185s but i plan on doing a rear suspension setup and need to know if there are any exhuast that i can slightly modify to use outside the frame instead of inside the frame. A couple I have found are the 200m, 200e, and 200es exhaust but i dont know if the frames are significantly different or if I can simply just weld on a tab to bolt the exhaust on. Also would there be a possibility of a 200x exhaust fitting up? I know the cobra exhaust will do what I need but there a bit pricey for what I'm wanting to do, mainly looking at the DG exhaust. Anybody done this or know about it?
    3. 85 200m
    Sep 2013
    Saskatchewan, Canada
    661
    Would you be interested in selling the original 185 front fender?? PM me.
    Dec 2014
    Lexington, KY
    117
    On my suspended 185s build I used a DG exhaust for a 200x. I had to drill into a prm grab bar for a mount point but it fits and holds good. There is a bottom mount I'm not currently using. I have posted a picture below. There is a little more about it in my build thread. There is also a video of it running so you can hear the exhaust. If your interested the link is in my signature. And below is a link to the exhaust I bought
    http://m.ebay.com/itm/DG-RCM-Steel-A...257Ciid%253A12
    1982 ATC185s
    1982 Suspended ATC185s
    1984 ATC70
    1984 ATC 250r
    19?? Motorcraft Three wheeler
    1974 Pacesetter 3
    1984 kawasaki 185
    1977 Atc 90
    1983 ATC 200x
    My suspended ATC185s build thread.
    http://www.3wheelerworld.com/showthr...s-Build-Thread
    plevib's Avatar
    Dec 2015
    North Dakota, USA
    358
    Woah Woah Woah! You can't just update with a picture with a custom rear suspension and not elaborate!
    ZacH_GrifF's Avatar
    Jul 2011
    Pearl, MS
    405
    That's not my bike plevib. Hopper055 thank you, I actually found your thread after I posted the question, that thread helps a lot thanks. I'm actually looking to adapt a warrior 350 swingarm for my rear suspension I just need to know the carrier mount width at the end of the swingarm and the pivot tube diameter.
    3. 85 200m
    ZacH_GrifF's Avatar
    Jul 2011
    Pearl, MS
    405
    Little more progress. Spent $30 on bolts... I hate hardware is so expensive. Got the motor all torqued and pressure washed just needs primer and paint. Gotta order some more parts but I can begin making a new wiring harness now.
ID:	240080Click image for larger version.
ID:	240081Click image for larger version.
ID:	240082Click image for larger version.
ID:	240083Click image for larger version.
ID:	240084Click image for larger version.
ID:	240085Click image for larger version.
ID:	240086Click image for larger version.
ID:	240087Click image for larger version.
    3. 85 200m
