Page 2 of 9 FirstFirst 1 2 3 4 ... LastLast
Results 16 to 30 of 121
Thread: Brandon's Tri-Z Build Thread
    Mexico
    9,012
    Looking a little closer at your photos there are a couple of other things you might want to check.
    Your rear brake adjuster lock nut seems to have come loose and it looks like your rear sprocket holder has some shiny spots on the inside of it on the posts that the bolts thread into. That usually means that either the axle carrier came loose at some point and started rubbing on the swingarm, or your axle bearings are shot and it's causing the axle to pull against The swing arm. You'll be able to tell for sure by looking at the swingarm for any gouges. If in fact the sprocket carrier has been rubbing against the swingarm you need to take a good look at it and make sure that it isn't cracked. I don't think by the slight amount of rubbing that I think I can see that you would have damaged the swingarm yet.
    It sucks to get old
    brandonlowe2's Avatar
    brandonlowe2 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    May 2016
    Georgia
    412
    That makes sense about the rear brake because it stopped working properly on the last ride.... i only had to barely touch it as the rear brakes would lock up....
    I am planning on rebuilding (or replacing if need be) all of the brakes so hopefully that will solve that
    1983 Selvy 300R - Check out the Build Thread
    1985/86 Tri-Z - Build Thread Coming Soon
    1985 Tri-Z
    1986 250sx
    1985 ATC70
    1985 ATC 200M
    Youtube Channel "Lowe Off Road"
    - Brandon
    May 2016
    Georgia
    412
    As far as the axle, when I get home next week I will be tearing it down more and I will post more pictures of the swing arm. I hope it is ok... the axle is getting replaced anyway as well as the sprockets and everything else back there but I hope to keep the swingarm
    1985 Tri-Z
    1986 250sx
    1985 ATC70
    1985 ATC 200M
    - Brandon
    Mexico
    9,012
    What's wrong with the axle?
    It sucks to get old
    Jul 2012
    Seattle, Washington
    1,544
    I bought a newer kickstart for my tri z, you can have my old one for $30.00 shipped. It is pretty loose, it flips out when you ride...but its a stock tri z kicker.
    Jan 2013
    minnesota
    5,911
    Quote Originally Posted by brandonlowe2 View Post
    Well crap... i need to find one
    There are three NOS ones on Ebay right now . The one below being the "cheapest" at only $165.00 including shipping, which is a whopping 42.107% less than your new headlight is gonna cost ya if that's any consolation.
    http://www.ebay.com/itm/Yamaha-Kicks...pXu4kv&vxp=mtr
    PREVIOUS KAWASAKI INTERNATIONAL R & D PROJECT ENGINEER AND ATV DEPARTMENT SUPERVISOR
    May 2016
    Georgia
    412
    Nothing is "wrong" with it but I want to get a +1-+4 adjustable axle for a wider stance
    1985 Tri-Z
    1986 250sx
    1985 ATC70
    1985 ATC 200M
    - Brandon
    Mexico
    9,012
    You might want to consider a set of offset rims instead. Besides being a lot cheaper than an axle, it's something you can change in a few minutes. Not sure what your trails are like, but I find my stock axle with the rims mounted in the widest position to be a little to wide at times down here.
    It sucks to get old
    May 2016
    Georgia
    412
    I'm pretty set on a new axle, however I had not even considered your idea. What wheels do you have?
    1985 Tri-Z
    1986 250sx
    1985 ATC70
    1985 ATC 200M
    - Brandon
    May 2016
    Georgia
    412
    Here are some more "before" shots.... getting it stripped down. Taking plenty of pictures to avoid any problems getting it back together :-)
Name:	2017-01-11 21.50.35.jpg
ID:	238692Click image for larger version.
Name:	2017-01-11 21.50.40.jpg
ID:	238693Click image for larger version.
Name:	2017-01-11 22.05.54.jpg
ID:	238694Click image for larger version.
Name:	2017-01-11 22.06.01.jpg
ID:	238695Click image for larger version.
Name:	2017-01-11 22.06.05.jpg
ID:	238696Click image for larger version.
Name:	2017-01-11 22.13.30.jpg
ID:	238697Click image for larger version.
Name:	2017-01-11 22.13.40.jpg
ID:	238698Click image for larger version.
Name:	2017-01-11 22.24.04.jpg
ID:	238699Click image for larger version.
Name:	2017-01-11 22.24.27.jpg
ID:	238700Click image for larger version.
Name:	2017-01-11 22.26.31.jpg
ID:	238701Click image for larger version.
Name:	2017-01-11 22.26.33.jpg
ID:	238702Click image for larger version.
Name:	2017-01-11 22.28.20.jpg
ID:	238703Click image for larger version.
Name:	2017-01-11 22.28.23.jpg
ID:	238704Click image for larger version.
Name:	2017-01-11 22.28.27.jpg
ID:	238705Click image for larger version.
Name:	2017-01-11 22.30.52.jpg
ID:	238706Click image for larger version.
Name:	2017-01-11 22.30.54.jpg
ID:	238707Click image for larger version.
Name:	2017-01-11 22.30.58.jpg
ID:	238708Click image for larger version.
Name:	2017-01-11 22.31.09.jpg
ID:	238709Click image for larger version.
Name:	2017-01-11 22.32.03.jpg
ID:	238710Click image for larger version.
Name:	2017-01-11 22.34.09.jpg
ID:	238711Click image for larger version.
Name:	2017-01-11 22.35.28.jpg
ID:	238712Click image for larger version.
Name:	2017-01-11 22.35.39.jpg
ID:	238713Click image for larger version.
Name:	2017-01-11 22.45.46.jpg
ID:	238714Click image for larger version.
Name:	2017-01-11 22.51.00.jpg
ID:	238715Click image for larger version.
Name:	2017-01-11 22.51.11.jpg
ID:	238716Click image for larger version.
Name:	2017-01-11 22.51.15.jpg
ID:	238717Click image for larger version.
Name:	2017-01-11 22.51.22.jpg
ID:	238718Click image for larger version.
Name:	2017-01-11 22.51.58.jpg
ID:	238719Click image for larger version.
Name:	2017-01-11 23.32.15.jpg
ID:	238720Click image for larger version.
Name:	2017-01-11 23.32.21.jpg
ID:	238721Click image for larger version.
Name:	2017-01-11 23.32.32.jpg
    1985 Tri-Z
    1986 250sx
    1985 ATC70
    1985 ATC 200M
    - Brandon
    May 2016
    Georgia
    412
    Well... last night really sucked. Trying to get the swingarm bolt out for over an hour.... heated up the bearings.... greased it..... oiled it..... beat the absolute crap out of the and managed to move it all of 1 inch..... then, the worst happened.... I missed and hit the crank case.... put a nice pretty hole in it, and of course covered the garage floor with oil. If thats not bad enough, the thing fell over and landed on the water impeller cover and broke it. I found a new impeller cover only cost 16 bucks... the crank case cover however I can't find one anywhere. If anybody happens to have one, please let me know.
Name:	2017-01-12 18.16.52.jpg
ID:	238771Click image for larger version.
Name:	2017-01-12 18.16.56.jpg
ID:	238772Click image for larger version.
Name:	2017-01-12 18.16.58.jpg
ID:	238773Click image for larger version.
Name:	2017-01-12 18.17.05.jpg
ID:	238774Click image for larger version.
Name:	2017-01-12 18.17.09.jpg
ID:	238775Click image for larger version.
Name:	2017-01-12 18.17.18.jpg
ID:	238776Click image for larger version.
Name:	2017-01-12 18.17.24.jpg
ID:	238777Click image for larger version.
Name:	2017-01-12 18.17.30.jpg
ID:	238778Click image for larger version.
Name:	2017-01-12 19.56.39.jpg
ID:	238779Click image for larger version.
Name:	2017-01-12 19.56.43.jpg
ID:	238780Click image for larger version.
Name:	2017-01-12 21.01.58.jpg
ID:	238781Click image for larger version.
Name:	2017-01-12 21.17.37.jpg
ID:	238782Click image for larger version.
Name:	2017-01-12 21.17.42.jpg
    1985 Tri-Z
    1986 250sx
    1985 ATC70
    1985 ATC 200M
    - Brandon
    House Springs MO
    5,496
    To show the power the edit button possessed by all non internet degenerates, I'm deleting my posts in hopes of getting this poor guys thread back on track. Too bad a mod has to perform these duties for others without such powers.
    Last edited by bkm; 01-14-2017 at 01:55 PM. Reason: because I'm not a degen and have an edit button
    May 2016
    Georgia
    412
    yeap..... i realize that :-(
    1985 Tri-Z
    1986 250sx
    1985 ATC70
    1985 ATC 200M
    - Brandon
    Jan 2013
    minnesota
    5,911
    You did not break the worst possible piece on the bike . It would be far worse to break your engine cases . If the cover is aluminum you can have it tig welded no problem.
    KROIL Oil is the best oil to soak a rusty item with to get it to move.
  15. #30
    Jan 2013
    minnesota
    5,911
    Send a pm to member 3 Wheel Drive and ask if he has one.
