Use a blaster engine, that would be cool!
Sorry i dont have any extra covers.
Also Propane doesn't get hot enough to do anything. Go pick up some MAPP gas.
85 Tri-z Basket Case
Brandon, I just looked at the cover on my 85 Tri Z and it is aluminum, therefore, your cover can easily be repaired by and experienced aluminum welder.
PREVIOUS KAWASAKI INTERNATIONAL R & D PROJECT ENGINEER AND ATV DEPARTMENT SUPERVISOR
thankfully I have no need for oem or original VIN (registration not required in Georgia) so whether they are a dime a dozen or if there is not one left in the world the fact remains I need one, or I need to fix mine.
If anybody has one or knows where I can source one that would be great but first we will attempt to fix this one and try not to make it an eye sore lol.... it will be powdered black anyway so probably won't ever be able to tell.
1983 Selvy 300R - Check out the Build Thread
1985/86 Tri-Z - Build Thread Coming Soon
1985 Tri-Z
1986 250sx
1985 ATC70
1985 ATC 200M
Youtube Channel "Lowe Off Road"
- Brandon
There is no vin on a clutch cover.
I suggested in a previous post that you send 3 Wheel Drive a pm and ask him.
That can be repaired to be 100% perfect on the outside if someone competent is doing it . I have done it several times . Save the broken pieces and give them to the welder.
3 wheel drive says he does not have one.... fixing it will be the way we go!
1985 Tri-Z
1986 250sx
1985 ATC70
1985 ATC 200M
- Brandon
Brenden yaeger is doing my rebuild and he said his welder is really good so if he trusts him I trust him
1985 Tri-Z
1986 250sx
1985 ATC70
1985 ATC 200M
- Brandon
I wouldn't let anyone do it without the condition that it be perfect on the outside otherwise they will not get paid . The most it should cost is around $120.00 . If someone wants much more than that I would send it elsewhere.
Since you are having it rebuilt, you should have the cases checked where the cylinder mounts for being both level where the 2 halves meet and for being flat . I would do the same with the cylinder base because both of these can warp.
I would also get some type of warranty in writing for the work performed from whomever builds it.
Hey guys.... I didn't mean to open a can of worms here.... but at the end of the day, I don't care where the cover comes from as long as it says Yamaha.
I will make sure the guy knows what he is doing.... his reputation precedes him as doing very high quality work
1985 Tri-Z
1986 250sx
1985 ATC70
1985 ATC 200M
- Brandon
Barnett what year Z do you have?
1985 Tri-Z
1986 250sx
1985 ATC70
1985 ATC 200M
- Brandon
Nice..... well if any of y'all see a cover for sale let me know. Hopefully the weld job will go good.... I'm off to cut the swingarm off!
1985 Tri-Z
1986 250sx
1985 ATC70
1985 ATC 200M
- Brandon
Oh, and Barnett post pics of your Z here (and anybody else in this thread with a Z). I wanna see all the Z builds I can to get ideas for mine
1985 Tri-Z
1986 250sx
1985 ATC70
1985 ATC 200M
- Brandon
