Upcoming Events for the Next 120 Day(s)
Results 1 to 12 of 12
Thread: Looking at picking up a 1983 200ES Big Red. Thoughts?
    May 2016
    Hamilton,ON.Canada
    867
    Looking for a trike for the GF.
ID:	238500Click image for larger version.
ID:	238501Click image for larger version.
ID:	238502Click image for larger version.
    Guy is asking $600.00 CAN OBO.
    How are these models overall? Things to look for? Besides smoke and brakes. Might go to check it out tomorrow. Needs rear tires. Guy also wanted to trade for hunting equiptment. I almost offered up my X wife.
    dman10's Avatar
    dman10 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jul 2013
    Elgin, TX
    396
    I owned one for awhile, was beat to hell when i bought it, but worked great till we ran it out of oil. oops. tough little machines. id check oil, chain, bearings etc. the standard stuff.
    Quote Originally Posted by tri again View Post
    Cool stuff seems to happen when I'm sleeping.
    Nice to know things happen without me.
    arlaunch's Avatar
    arlaunch is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2014
    Oregon City
    343
    As always....
    ATC's that cost $600 will need $3000 to repair. Then it will be worth $800
    LOL
    HAHAHA
    The forks are the weak part of these machines. My 84 has a drive shaft. Use Hypoid gear oil
    Keep the battery on a tender.
    The 84's had reverse
    The 85's got real hydraulic forks and a rear shock.
    1984 Honda Big Red ATC 200ES (Emma)
    1985 Honda 200X ATC (Pretty Boy)
    1985 Honda 250R ATC (Dr. Fast)
    1985 Honda 250R ATC ( 77 )
    1985 Honda 250R ATC (Baller)
    1986 Honda 350X ATC (Go Go Girl)
    Feed Back: http://www.3wheelerworld.com/showthr...k-for-arlaunch
    Sep 2013
    Saskatchewan, Canada
    501
    Love my '84 200es - never leaves me stranded. Do the required maintenance and it will run forever. No major issues with mine. Your GF will love it. When my wife hits the trail - the 200es is the one she will chose from the fleet. Electric start, reverse and ease of use.
    If you go to look at the '83 and everything checks out good - I would put 4 x 100 dollar bills in front of the seller. If he does bite - add another $50.00. Max I would go is $500.00 - again only if everything checked out fine and runs/drives good. Hard to tell from the pics - looks decent - a little love and detailing and it would look good - everything appears to be there except the rear sub rack over the tool box and front and rear mud flaps - both easy finds on eBay.
    Good luck - let us know the outcome.
    Regards
    BK3 (Regina, Sask)
    Dec 2012
    750
    Coming from a fellow Canadian, I wouldn't jump on that one, $600 is too much. If you could get it for $400 I'd say yeah maybe, but even then I wouldn't call it a steal. I'd hold off for something else to come along. As mentioned you'll likely end up dumping a bit into it, and before you know it you realize you've paid way too much for it. That's been my experience anyways.
    1985 Honda ATC 250ES
    1985 Honda ATC 250SX
    1984 Honda ATC 200M
    1983 Honda ATC 200
    1984 Honda ATC 110
    Dec 2015
    Allegany County NY
    29
    No reverse, non rebuildable forks, and a chain drive are some unfavorable designs on the 82 and 83 200E's. Around my area 1985 250ES BIG REDS go from $700 on up. In my opinion it might be well worth it to spend more and get a 250ES - More power, some suspension, reverse, and shaft drive.
    JUSTBIGREDS.COM
    17 BIG REDS - (2) 1982 200E's, (2) 1983 200E's, (6) 1984 200ES's, (5) 1985 250ES's, (2) 1986 250ES's
    1985 250SX
    1985 200X
    1984 200X
    1985 Tri-Moto 125
    BarnBoy is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jun 2015
    Oklahoma
    218
    '83 200E's are very very good machines. We have one on the farm. I got it running and we have been driving all over on it. That is one tough machine, it gets beat on running through the field, through the bush, up and down the road, etc, and still keeps on ticking like a clock. Only things we replaced were the battery, the exhaust as it was rusted out, and the oil/gas. Things to check are chain and sprockets for sure, but are easy and fairly cheap to replace. Make sure you check the oil too!
    If it runs and idles well with no smoke, and drives well, I don't think that asking price is a bit high but not too far off. You have to keep in mind when you compare CDN/US markets that $600 Canadian is around $450 US dollars. $700 USD is around $925 CDN, big difference. New rear tires could be used as a bargaining point, and you could probably get him to drop his price a bit from that, as they will run you at least 100 bucks, probably $150ish. I say it doesent hurt to go look at it and make an offer, worst he can say is no. You won't be disapointed with the big red's performance. Just my 2 cents.
    1984 HONDA ATC200M
    Feb 2013
    Walford, Iowa
    120
    Is it a 200E or 200ES? shaft drive or chain? We have had a 200e on our acreage for a couple years now and it always starts up. It is super impressive, it could sit for 3 months in below zero temperatures and it will alway start with in a dozen pulls. They are like any other honda 200cc motor, they will run forever and probably outlast all of us.
    Trikes Owned:
    1983 Honda 200x - Durablue Axle
    1986 Honda 250r - +2 westcoast
    1984 Honda ATC 70 - Piranha 140 swap
    1983 Honda 200e - Stepdads
    May 2016
    Hamilton,ON.Canada
    867
    Thanks for the replies. I really appreciate the help
    Guy is not responding to my emails and seems to be in rough condition and not very well maintained.
    Oh well. I will keep my eye out.
    Nov 2012
    Nova Scotia
    129
    I'm also from canada and that looks like a decent deal, look for stripped bolts, make sure no hubs are welded.
    honda4h's Avatar
    honda4h is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    ottawa ontario
    361
    if you were closer i have a 200es nice shape priced for 700 and it comes with a complete 200m fork set up with fender to swap out
    schlepp29 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2015
    stonecreek ohio usa
    319
    Front forks are usually junk. There good runners though. Make sure the shifter isn't welded to the shifter shaft. There fun bikes, run forever.
