Will a ATC 90 ignition coil work on a CT 90?
Hi all, I'm new and have a few different questions, but I figured I would ask this one first. I'm building a CT90 yes I know it's not a 3 wheeler the engines are very similar one of the difference is the 3 wheeler has a CDI ignition system and the CT90 has battery points. I want to know if the coil of a ATC would work on the CT. My other questions will be more about 3 wheelers just wanted to get this one out of the way and test the waters.
The best way to know is to check the specs in their manuals. If they're the same then you can swap them.
//ArrowChat Integreation Code
