My 1985 ytm200
Hey, i have a 1985 ytm200 trike it seems to run quite nicely and has little issues. But anyways i was woundering if there was a larger size carb i could put on to it. Do you think i could manage to fit one on from a dirt bike or something similar. Something bigger than the stock 22mm carb to give it some more prep.
You could try a bear tracker carb. I believe they are 34mm. The motors are very similar between the two.
Thanks for the help, but i tried doing some looking around and i cant seem to figure out if it will fit properly. Do you have any info on this?
Are you talking the 2001 250 bear tracker carb (BST34/1
MIKUNI) . If so. I cant seem to find any information on the size of the intake boot
The intake boot should bolt on to the head. Not sure about fitment between the frame.
//ArrowChat Integreation Code
