Title says it all, is it a common problem? It has 25x12x9 mudlites but that shouldnt effect it.
1983 ATC 185s 200 jug bored .20 9.5:1 Naumura piston. Fast as ass when its not stretching the drive chain or stripping hubs.
1986 ATC 250ES. *Total garbage trying to sell it*
1983 YTM 200E. Runs good, forks are super bent but aside from that its mint.
1984 YTM 200L. Barn find, everything is mint except the bottom end is bad... *waiting on a new engine*
Can you see or feel any play when shaking the rear tires? Could be axle bearings.
I'm gonna bring it into the shop today.
Could the brake shoes be rubbing the drum at all? Mine makes a squeak when I go backwards sometimes.
1980 ATC 70 Needs Restoration
1985 ATC 250es Fully Refurbed
1986 ATC 350x Mint Original
Order a axle bearing kit and shoes cause there going to fall off when you removed the drum. Cause if you like playing in the water/mud you probably have had water in there some where. As for the axle bearings make sure year and vin work with the bike/rear end you have cause there are vin brakes in bearings fit what rear end no matter of year
Well I took the diff off the swing arm, axle bearings are shot, but there was a lot of gear oil by the driveshaft, I assume my pinion seal is bad?
Well yea I would say the seal is bad. You might as well reseal and replace all the bearings in the rear end and it will be good for another 30 years
Your pinion bearing will also be shot,just rebuild all of the diff and rear and you will be G2G for another 30.
