Ok, that explains why you only noticed a small difference . If you put an internal rotor one on it, you will notice a very large difference . It will also be much easier to kill the engine when braking plus it will rev quicker once it comes on the power band so it will also be less tractable and will basically have less bottom end torque.
You also need to pay close attention to timing because different units have different timing curves and it is easy to toast a piston with incorrect timing . To get the most out of a non stock type stator, it is best to have it dyno tuned . This way you can monitor the detonation if they have a deto sensor and you can monitor the jetting and engine temp vs the horsepower and rpm etc . If you don't dyno tune it, I would at least get a temp gauge and test with that . A tach would also help . With both items you could plot a graph and check the relationship between the two with different timing settings.
At least this is what Google search tells me.
Why, do you have an aversion to traction? You will also kill it every time you barely touch the brakes.
PREVIOUS KAWASAKI INTERNATIONAL R & D PROJECT ENGINEER AND ATV DEPARTMENT SUPERVISOR
AND OWNER OF A TRI Z THAT ACTUALLY HAS A REAR SHOCK ON IT
