This is a tough one,
I can't help much... Just share an experience for the sake of BS'ing on the forum. I bought my ATC 200ES not running. The guy said it ran 2 hours before i got there. I ended up cleaning the carb. It would not run. It would do the same thing. Start kind of. I thought since it ran i must have good spark.
Fast forward to a new Chinese carb. Boom.... LoL same crap. I check spark. (should have done this first) Intermittent at best.
Get new plug. Fires right up and runs perfect. Except for being a bit bigger carb and running way to rich up top. No problem for the rest of the summer.
Then it sits for awhile. The thing seems to be getting harder and harder to start and the plugs are bit dark. It always fired up though.
This winter i needed the thing and decided to get it running. It would not start. I likely got the starter hot a couple times trying too. I ended taking a wire brush to the plug to clean it off and rebuilt the factory carb with all OEM
parts.
There i was, I pushed the start button for 1/4 second and it fired right up. It needed the usual adjustments.
Point being,
If the carb is clean and put together correctly it will fire up without countless seconds of killing your battery and starter.
I recommend declaring war on this thing.
Get the shop manual, and the owners manual out.
Find out every thing there is to know about its electrics. These things need to be in neutral, gas cap vent to open, switch to run, key on, fuel on. Pull your plug and let us know what color you are seeing.
Ensure that your fuel tank filter is not clogged and the carb is getting gas.
Drain the carb and ensure the carb bowl is holding fuel. That is a dead give away that the petcock filter is plugged.
Try to use only Non Ethanol fuel in these things.
Get OEM
parts here:
http://www.powersportsdiscount.com/o...c200es-a-parts
And please follow through with this post. So many get their machine running and then fade away.
Then people in your situation search and search a bunch of dead end crap threads....
Stay with us.
