Results 1 to 15 of 18
Thread: 86/86 250R DG Xtreme Pipe Feedback
    Feb 2006
    connecticut
    95
    Anyone running this pipe? I'm looking for a good all around pipe. I'm assuming it won't perform well with a 350/370 kit but the price makes it worth looking into. Wishful thinking I guess. Not really feeling $500 price tag on that ESR or CT exhaust.
    Feb 2006
    connecticut
    95
    ****85/86*** I can't edit the title. Can a moderator do so if one comes across this? Thanks
    Oct 2006
    2,502
    In my humble opinion skip the big bore and spend the money for a quality hand coned pipe on a stock motor.
    I can recommend you a couple others who will vouch for the impact of a quality hand coned pipe on a stock motor.
    efhondakid's Avatar
    efhondakid is offline At The Back Of The Pack Arm chair racerFirst time rider
    Feb 2015
    Canton Ohio
    203
    The ESR is a really good pipe, I found a used one in great shape for cheap. Already ran a uni filter and rejetted for that with the stock pipe. Put the ESR pipe and silencer and jetted again and the difference was night and day, quicker response and a a much broader power band.
    2 in the back, 1 in the front.
    Feb 2006
    connecticut
    95
    This is a complete frame up restoration. Big bore kit is a must since I'm already splitting the cases to have them powder coated. If ESR would ever call me back that is! Everything is over the top on this build. Almost ten years in the making, im determined to have one of the sickest non drag, non dune specific R's in the country. I'll start a build thread in the next few days. But yeah, I was figuring there was no beating the ESR or CT pipes. I see everyone always comparing FMF to them. Just not DG.
    Oct 2006
    2,502
    If you are doing a bulld as you describe then why stop short with the pipe? Keister on the boards just removed his esr for a hand coned pipe. The guy who bought it then rode my 250r, and his esr is now for sale Do what you like but it's your build, good luck.
    Feb 2006
    connecticut
    95
    Just wishful thinking and curiosity on the DG. I know nothing of hand coned pipes really. I'm interested in the performance gains over the ESR and who makes them now though. Any help is appreciated
    Oct 2006
    2,502
    I will get you some information and pics of my pipes!!
    Oct 2006
    2,502
    Kenny Roberts pipes. There is another builder, but this is my choice.
    efhondakid's Avatar
    Feb 2015
    Canton Ohio
    203
    I'm with Mr. Clean, in the instance of an all out build like you described would benefit most fron a pipe custom tailored to your motor.
    May 2015
    San Diego, CA
    1,747
    Buildandclick.com
    The software is very easy to use and navigate through. If i can understand it anyone can. Prints out templates for each section.
    I've never made one yet as I feel my tig skills are not ready (that good). Even if you never attempt one......for under $40 it's good info.
    Feb 2006
    connecticut
    95
    I'm definitely interested in the hand coned pipe. Doing a little research, are the Kenny Roberts pipes the ones coming from BDT? Any thoughts on LED?
    Arizona
    844
    Yeah, Kenny Roberts makes pipes for BDT and plan on spending $850. Arlan at LED makes standard and big bore pipes for the R. You might get his for a little less than $850, but not much.
    Dec 2013
    Coachella Valley, Calif
    124
    I have no 1st hand experience, but a good friend has a 370 cc ESR that was carefully ported to perfection contracted by Rob Selvy @ "BDT" , he later added a "Kenny Roberts" built pipe, He said is was a performance gain. My friends tell me its one of the fastest all around 250Rs they have ever seen ?, & Mr. Selvy stated to him its right there with the strongest build hes ever accomplished. Its no simple bolt on, it starts w a ESR cylinder, then its modified, the head had extensive time invested as did the crank.
    Note* Its faster than a CPI 421 powervalved Banshee thats been dynoed at 93 h.p thats frankly... one quick 250R as its not a dedicated drag bike, its supposed to be a a rideable duner.
    It was expensive and time quite time cosuming more than a 1yr at the shops ...4-5 grand I beleive ? Pipe was around $700.00 -900.00 bucks if I recall. If your after specifics I should be able to find out.
    I do know 2 stroke 101, that if one is doing a big bore and wanting to maximize power, a pipe built to the port design, head design and riding style is a no brainer.
    I need all the help I can get!
    kevin is offline At The Back Of The Pack Arm chair racerFirst time rider
    Mar 2011
    Manitoba
    172
    Buildandclick.com
    Does this software give you bike specific dimensions?
