Results 1 to 10 of 10
Thread: removing paint from fenders?
    Pekin IL
    529
    I picked up a 97 ktm jr that's in great shape, except the po painted it red. any thoughts on removing it without damaging the fenders?
    Sent from my SM-G935V using Tapatalk
    1985 250r
    1985 200s
    1984 200x
    bandito x2
    1979 atc70
    Trikefest 2012,13,14,15
    May 2015
    Watford city, North Dakota United States "THE BAKKEN" / Lebanon, Oregon United states.
    1,081
    I heard (haven't had to try it yet) that airstripper works. Try a pressure washer first tho
    Saying "it's the trikes fault" is like saying "guns kill people"
    don't poke the bear... you'll get banned
    Queef Chief's Avatar
    Queef Chief is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jul 2015
    Rineyville, KY
    231
    I've used paint stripper with success. I think the key is not to let it soak long, as it seems to soften the plastic. Last time I stripped a set of painted plastics, I let stripper set for 60 seconds and used pressure washer. It may take a few attempts to get it all off.
    Pekin IL
    529
    I wasn't sure if I could use stripper or not. Will give it a shot tonight and update. thanks guys
    1985 250r
    1985 200s
    1984 200x
    bandito x2
    1979 atc70
    Mar 2013
    Baldwin, Wi
    603
    I used this on my Tri-z fenders with no issues. Picked up from a local auto parts store. I believe they have different types, read the cans 1 should say plastic safe.
    http://shop.advanceautoparts.com/p/p...322/10035245-P
    I've also head many times to use brake fluid. Should eat up the paint and wont hurt the plastic. I've never tried this personally but i have seen it spilled on motorcycle fender and it takes the paint off.
    85 Tri-z Basket Case
    We have used dads paint stripper many times just use rubber gloves a old paint brush and garden hose to wash it off between coats. Just brush it on and keep going back over all the spots till it wrinkles up and wipe off then hose it off and reapply until all the paints gone. We haven't ever hurt any plastic doing it that way
    Slidell, LA
    4,737
    Brake fluid
    Jul 2003
    indiana
    891
    Yep, brake fluid. Bye bye paint
    Manheim, PA
    5,742
    paint stripper...it dont hurt . follow up with purple power. brake fuild will do it also with steel wool but takes forever. These plastics were stripped on both bikes.
    i use kleen strip in air-sole can...you get it on your skin you will learn what acid on your skin feels like...but it works as you can see.
    6bt's Avatar
    6bt is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jan 2017
    near Syracuse NY
    318
    I've had great luck with aircraft stripper, hasn't bothered plastic yet for me.
    Sent from my XT1254 using Tapatalk
