Results 1 to 15 of 16
Thread: Lug Nuts on Douglas Rims
    Popeye is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Oct 2011
    MS
    301
    I just bought a pair of douglas rear rims for my auto x build. They not in yet, but just wondering if they take the tapered lug nuts or the flat. I have stock 85 200x hubs.
    Thanks
    1984 Honda ATC 300r (Project Trike)
    1981 Honda ATC 200 (Daily Rider/Hunting Trike)
    Arizona
    844
    As far as I know Douglas doesn't make a rim with tapered inserts anymore. ITP does, it is their A6 Pro Series GP.
    Oct 2011
    MS
    301
    Thanks man
    Don't forget that OEM wheels are super strong.
    I'd take a set of them, (and they do pop up on EBAY from time to time; Many rims fit many vehicles), over aftermarket any day.
    There was a gold rim I was using on my 350X. One had an edge to it, and the other was rolled to maybe a 10mm wide rolled face. They were super strong...
    Blossvale NY
    4,567
    You can get non-tapered flange lugnuts from Rocky Mountain ATV too if you end up with rims that don't have tapered holes. I'm with DC, there are some good AM rims out there, but a good set of OEM are hard to beat too. I think the tapered automotive style lugs are inherently a tougher design.
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 200ES Big Red
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
    Apr 2014
    Edmond, KS
    2,535
    A little while back, I bought a set of lug nuts on Ebay from a guy who goes by the name of xcbob. They're the flat, shouldered type, but they come with cone inserts so they can be used with either type of rim. $9.95 + $3.39 shipping. I haven't tried them yet, but they're going on my 350x.
    All you need are 8 metric flange nuts. You can get them at any decent hardware store.
    Blossvale NY
    4,567
    True true.. just get them with a smooth flange. Textured flanges, the type designed to have locking ability will chew on your rims every time to remove and replace them. Bought a set of textured flange nuts for a chainsaw bar nuts once and couldnt believe how fast they started to chew up the magnesium clutch cover
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
    NEPA
    7,048
    Just turn your stock nuts around. That's all we ever did.
    Scootertrash's Avatar
    In the sticks
    4,628
    I use nylock nuts with a washer to help prevent damage to the aluminum rim.
    Jul 2013
    USA
    738
    You are using nylon washers too? Seems ok if you keep them tight.
    In the sticks
    4,628
    Steel washer
    Connecticut
    1,605
    So the inserts from xcbob would work on a stock Honda rim that is missing the original insert?
    Seems like HONDA doesn't offer that piece to rims separately? If I am wrong someone please post the part number for a stock 400ex Rim
    Here is a link to the auction where pic is from... http://www.ebay.com/itm/Tapered-Lug-...gAAOSwpDdU211G
    Apr 2014
    Edmond, KS
    2,535
    I don't know about the missing Honda insert. They would work with rims that either take flat or tapered lug nuts. Here's what I bought them for. Click image for larger version.
ID:	240271These are supposed to be stock 400ex take off rims. They use the flat type of lug nut. You can see that they have been mounted, but they still look almost new. I think they'll make the back of my 350x look better.
    NEPA
    7,048
    They are ITP rims,not Honda,and they are most certainly used. Turn your stock nuts around and ride. Recheck them after a few rides until you are confident they aren't going anywhere..
