So, with a little legwork, you can get all the answers regarding what is interchangeable with what. It takes a little time, but it is very straightforward to look up the parts.
There is a pretty cool feature you can take advantage of on the on-line OEM parts sites.
Navigate to the part you have (by picking the year, make, and model of the machine you have and locate the Honda part number.
For example, the 1985 Honda Big Red 250ES front brake shoes are part number: 06430-HF7-A30
(link here: http://www.cyclepartsnation.com/oemp...nt-brake-panel )
Then, using the same site, just look up the part number itself. At this link: http://www.cyclepartsnation.com/oemparts/c/honda/parts
on the right side of the screen you'll see a search box. Paste in the part number you have and search for it. It will give you lots of hits, but notice that to the far right of the search results, there is another link that says "Where Used"...
There you have it, after clicking that link every place that part number is used gets listed. Just for your reference, the front brake shoes in question from the 1985 250ES are also used on:
1977 ATC90 A - BRAKE / REAR HUB
1978 ATC90 A - BRAKE / REAR HUB
1979 ATC110 A - REAR BRAKE DRUM
1980 ATC110 A - REAR BRAKE DRUM
1980 ATC185 A - REAR BRAKE DRUM
1981 ATC110 A - REAR BRAKE DRUM
1981 ATC185S A - REAR BRAKE DRUM
1981 ATC200 A - REAR BRAKE DRUM
1981 ATC250R A - REAR BRAKE DRUM
1982 ATC110 A - REAR BRAKE DRUM
1982 ATC185S A - REAR BRAKE DRUM
1982 ATC200 A - REAR BRAKE DRUM
1983 ATC110 A - REAR BRAKE DRUM
1983 ATC185S A - REAR BRAKE DRUM
1983 ATC200 A - REAR BRAKE DRUM
1984 ATC110 A - REAR BRAKE DRUM
1984 ATC200ES A - REAR BRAKE DRUM
1985 ATC110 A - REAR BRAKE DRUM
1985 ATC250ES A - FRONT BRAKE PANEL
1985 ATC250SX A - FRONT BRAKE PANEL
1985 TRX125 A - REAR BRAKE DRUM
1986 ATC125M A - REAR BRAKE DRUM
1986 ATC250ES A - FRONT BRAKE PANEL
1986 ATC250SX A - FRONT BRAKE PANEL
1986 TRX125 A - REAR BRAKE DRUM
1986 TRX200SX A - REAR BRAKE DRUM
1987 ATC125M A - REAR BRAKE DRUM
1987 ATC250ES A - FRONT BRAKE PANEL
1987 ATC250SX A - FRONT BRAKE PANEL
1987 TRX125 A - REAR BRAKE DRUM
1987 TRX200SX A - REAR BRAKE DRUM
1988 TRX125 A - REAR BRAKE DRUM
1988 TRX200SX A - REAR BRAKE DRUM
1991 TRX200 A - REAR BRAKE DRUM
1991 TRX200 AN - REAR BRAKE DRUM
1991 TRX200D A - REAR BRAKE DRUM
1991 TRX200D AN - REAR BRAKE DRUM
1977 FL250 A - REAR BRAKE DRUM / REAR BRAKE
1978 FL250 A - REAR BRAKE DRUM / REAR BRAKE
1979 FL250 A - REAR BRAKE DRUM / REAR BRAKE
1980 FL250 A - REAR BRAKE DRUM / REAR BRAKE
1981 FL250 A - REAR BRAKE DRUM / REAR BRAKE
1982 ATC200E A - REAR BRAKE DRUM
1982 FL250 A - REAR BRAKE DRUM / REAR BRAKE
1983 ATC200E A - REAR BRAKE DRUM
1983 FL250 A - REAR BRAKE DRUM / REAR BRAKE
1984 ATC125M A - REAR BRAKE DRUM
1984 ATC200M A - REAR BRAKE DRUM
1984 ATC200S A - REAR BRAKE DRUM
1984 FL250 A - REAR BRAKE DRUM / REAR BRAKE
1984 TRX200 A - REAR BRAKE DRUM
1985 ATC125M A - REAR BRAKE DRUM
1985 ATC200S A - REAR BRAKE DRUM
1986 ATC200S A - REAR BRAKE DRUM
1990 TRX200 A - REAR BRAKE DRUM
1992 TRX200D A - REAR BRAKE DRUM
1992 TRX200D AN - REAR BRAKE DRUM
1993 TRX200D A - REAR BRAKE DRUM
1993 TRX200D AN - REAR BRAKE DRUM
1993 TRX90 A - REAR BRAKE DRUM
1994 TRX200D A - REAR BRAKE DRUM
1994 TRX200D AN - REAR BRAKE DRUM
1994 TRX90 A - REAR BRAKE DRUM
1995 TRX200D A - REAR BRAKE DRUM
1995 TRX200D AN - REAR BRAKE DRUM
1995 TRX90 A - REAR BRAKE DRUM
1996 TRX200D A - REAR BRAKE DRUM
1996 TRX200D AN - REAR BRAKE DRUM
1996 TRX90 A - REAR BRAKE DRUM
1997 TRX200D A - REAR BRAKE DRUM
1997 TRX200D AN - REAR BRAKE DRUM
1997 TRX90 A - REAR BRAKE DRUM
1998 TRX90 A - REAR BRAKE DRUM
1999 TRX90 A - REAR BRAKE DRUM
2000 TRX90 A - REAR BRAKE DRUM
2001 TRX90 A - REAR BRAKE DRUM
2002 TRX90 A - REAR BRAKE DRUM
2003 TRX90 A - REAR BRAKE DRUM
2004 TRX90 A - REAR BRAKE DRUM
2005 TRX90 A - REAR BRAKE DRUM
2006 TRX90 AC - REAR BRAKE PANEL
2007 TRX90EX 3AC - REAR BRAKE PANEL
2007 TRX90EX AC - REAR BRAKE PANEL
2008 TRX90EX A - REAR BRAKE PANEL
2009 TRX90X A - REAR BRAKE PANEL
2012 TRX90X A - REAR BRAKE PANEL
2013 TRX90X AC - REAR BRAKE PANEL
2014 TRX90X AC - REAR BRAKE PANEL
2015 TRX90X AC - REAR BRAKE PANEL
2016 TRX90X AC - REAR BRAKE PANEL
2017 TRX90X AC - REAR BRAKE PANEL
- Frank
1984 200ES Big Red
1985 350X (x2)
1986 350X
1986 250SX
1984 Auto-X
1984 ATC70
1985 ATC70
