Results 1 to 9 of 9
Thread: Air box
    Feb 2017
    Paragould
    63
    Air box
    How the hell do you get this back on?? Is there a trick or something??
    Feb 2017
    Paragould
    63
    Apr 2014
    Edmond, KS
    2,537
    On my sx, I like to attach to the airbox first. That way you can be sure that it is in place all the way around. You can see the part when it's on the carb and if it's no installed correctly, you can work it on. It helps a lot if the rubber's not hard from old age. If yours is, maybe you can soften it up with a hair dryer or a carefully used heat gun.
    Connecticut
    1,605
    Also totally loosen up the clamps. Most times I will unhook the clamps completely so you are able to manipulate the air box hose
    Feb 2017
    Paragould
    63
    It's hard because of old age that's why it's so hard
    Connecticut
    1,605
    Use lots of WD40 and try pushing on. People also boil the air box hoses and rubber intake manifolds to help make them more pliable if they are installing larger than stock carburetor
    Ranvier is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Sep 2016
    Phoenix, AZ
    307
    May 2015
    Watford city, North Dakota United States "THE BAKKEN" / Lebanon, Oregon United states.
    1,081
    Gotta man handle it!
    Sent from my SM-G935V using Tapatalk
    Saying "it's the trikes fault" is like saying "guns kill people"
    don't poke the bear... you'll get banned
    Mar 2016
    Kansas City, MO
    130
    I had a heck of a time getting mine back on my 200x. Basically, just get a side of it on, twist and push until it goes on. It's frustrating. Might try a little dawn dish soap also.
    Real men ride trikes!
