Page 191 of 311 FirstFirst ... 91 141 181 189 190 191 192 193 201 241 291 ... LastLast
Results 2,851 to 2,865 of 4660
  1. #2851
    Sep 2019
    Upstate NY, USA
    16
    Picked up my frame from the powder coater today. A few flaws where the powder was too heavy and just started to run, but overall I'm happy with how it turned out. That being said, I'm a bit hesitant to let them do the swingarm.
ID:	260343 Click image for larger version.
ID:	260344 Click image for larger version.
ID:	260345 Click image for larger version.
  2. #2852
    Mar 2009
    new england
    1,391
    So removed the bestop and put on the hard top
    Also dug out an LED light that neighbor was tossing. Temporarily mounted for fit. Now to make up some brackets and switch
    Let me know if u need the besttop
  3. #2853
    Mar 2009
    new england
    1,391
    2 days off
    Traded the 3/4 for 1 ton
    Wife is happier w/o lift and 37” but I hate the stance. So 3” Front/1” rear level kit going in. Also got to undercoat the ram/jeep and crane truck for winter
  4. #2854
    May 2015
    San Diego, CA
    1,789
    A customers son is selling his 1 ton.....nice lift, wheels, etc.
    I've looked into those Titans. Seems a good value but the Cummins motor is new.
  5. #2855
    Mar 2009
    new england
    1,391
    Directions= misleading, inaccurate
    Kit mostly complete= again, should not be my problem
    All told, about 3 hrs, could do it again in about 1/2 that knowing what I know now.
    Before:
    39” front/43” rear
    Apart:
    Final:
    43/43”
    Got to practice my endoscopic skills grabbing a dropped spacer in the frame
  6. #2856
    Mexico
    9,014
    Looks much better! Now if you could just peel off those Mopar tags....
  7. #2857
    Nov 2015
    Davenport iowa
    1,144
    Hahaha, all those years of schooling finally paid off. Nice job!
    1974 original 90 X 2
    1974 Original 70.
  8. #2858
    May 2015
    San Diego, CA
    1,789
    Barns has a couple of Kawasaki's......."THE MOST POWERFUL ATC IN THE UNIVERSE" for sale on ebay.
    His item description reads kinda like a post. I miss his presence here.
    https://rover.ebay.com/rover/0/0/0?m...2F202804798703
    https://rover.ebay.com/rover/0/0/0?m...2F202804798287
  9. #2859
    Mexico
    9,014
    Was I supposed to be wearing 3D glasses when I clicked on those links?
  10. #2860
    Soutwestern PA
    2,040
    I like how he included his resume in the eBay description.
    SELLER BACKGROUND
    I was a local Southern California Pro Motocross racer in the mid and late 70's. In the early 80's I got a job as a project engineer in the R & D department at Kawasaki Motors International where I did test riding, engineering, fabrication, and overall development of off road bikes, and atv's. I did virtually every second of the development testing of the 84, 85, and 86 Tecate's during this time.
    I also raced in the Pro class with the 84 pre-production Tecate that we used for testing which I modified with just a Harry Klemm port job, pipe, and plain old fifty dollar 36mm Mikuni carburetor, and I holeshot and won several races with it, including the last short track race at Saddleback Park, where I beat Jimmy White (who was the reigning champion at the time) and the factory honda riders with their bazillion dollar works trikes etc, so I know these trikes better than most anyone.
    So whatever happened to Barnett? When and why did he sign off this site? I feel like I missed something.
  11. #2861
    Nov 2015
    Davenport iowa
    1,144
    Finishing up on a new x-mas tree stand. I put up two 25-30’ live trees at my work. In the past we have always had issues trying to adjust the tree for straightness once it was up. These trees weigh between 5-600 pounds so once they were up in the previous stand I designed it was almost impossible to adjust them. Click image for larger version.
ID:	260649 this is last year stand. It sat on a base that was hinged. In theory you slide the trunk in, walk it up, and lock into place. Because of the adjustment issues we had I decided that an independent adjustable leg system would work best, put together with hitch pins for easy assembly and adjusting. Click image for larger version.
ID:	260650 this is what we came up with. We in theory should be able to adjust for straightness one of two ways By either the adjusting holes in the legs itself or by the turnbuckle. Here is the nearly finished design. Click image for larger version.
ID:	260651 I figure the only way this will really work is if I can hoist the trees and suspend them so I can get everything straight before lowering it to the ground. I am fortunate enough to have a structural beam running above where I need to stand these trees, so I’m thinking a electric hoist will do the job. Once everything is in place and straight we will attach the turnbuckle and cable and bolt the foot end to Two 3/4” pieces of plywood screwed together with carpet attached to the underneath so we can slide de the trees into place once the lights are on.
    1974 Original 70.
  12. #2862
    Mar 2009
    new england
    1,391
    Wow, quite the stand^
    Day of stands, here was mine today.
    5$ scrapyard stand adapted to new blade grinder
  13. #2863
    May 2015
    San Diego, CA
    1,789
    I think he got the boot no??
    What's more of a mystery is Glamy. I think all of his posts went bye bye and so did he......with the exception of the occasional likes and dislikes he leaves
  14. #2864
    Mar 2009
    new england
    1,391
    Got the ram/crane truck and cj5 undercoated today
    Fluid film was a bit thick at 60 deg, warmed up to 90-100 to be able to pour in spray containers
    1 gallon gave good coverage for all 3 vehicles (2/3 went on crane)
  15. #2865
    Nov 2015
    Davenport iowa
    1,144
    Plastico,
    Fluid film? What is that stuff? Is it like a permanent undercoating or something that you apply yearly? If permanent are you not concerned it will lock in place any dirt or rust that is already there?
    1974 Original 70.
