Page 193 of 313 FirstFirst ... 93 143 183 191 192 193 194 195 203 243 293 ... LastLast
Results 2,881 to 2,895 of 4682
  1. #2881
    Mar 2009
    new england
    1,391
    Hell of a stand
    Let us know how containment works, I considered buying something similar, basically a big weathertech
  2. #2882
    Nov 2015
    Davenport iowa
    1,144
    Hell of a stand
    You got me, containment? Weather tech?
    The b-link channel mounted on the ply wood will give us an additional option for adjusting along with the turnbuckle itself. I do believe that once everything is locked into place it should hold a 27’ 600 pound tree. One issue I’m going to Have is mounting the brackets to the tree so they are flush.
    1974 original 90 X 2
    1974 Original 70.
  3. #2883
    Nov 2015
    Davenport iowa
    1,144
    Hell of a stand
    Hey plastiko, I just figured out the reference to containment you spoke of, will definitely let you know. Wouldn’t break my heart if we didn’t have any winter weather this year.
    1974 Original 70.
  4. #2884
    Mar 2009
    new england
    1,391
    Sorry, I type like I think
    All over the place
  5. #2885
    Mar 2009
    new england
    1,391
    Finished up forging the bracket then took the Excalibur micro out for some target practice
    Soda can gives u reference as to how small this bow is. Weight is around 5 lbs. It still does 355ft/sec (280lb draw wt)
  6. #2886
    Mexico
    9,018
    Flat out busted hump today. Moved and burnt a cord? of rotting wood? I’m really not good with chords. Then cut down a rotting mesquite tree and stack the wood. My 16 inch chainsaw isn’t going to cut it (no pun intended) on this property. I overheated it at least six or seven times and it’s not long enough to go through the stumps that I’m going to need to trim down to the ground.
  7. #2887
    Mar 2009
    new england
    1,391
    Wow
    Lot of work!
  8. #2888
    Mar 2009
    new england
    1,391
    Wish this Stanford lift saw some oil. I figured I would make sure I could remove the ram before getting it installed. Glad I did. Pins had to be drilled out. Also started fitting the LED bracket after forging.
  9. #2889
    Aug 2016
    East of Worcester ma
    1,366
    You guys can keep your spiders, damn things scare the bejeezus outa me especially in under houses (crawl spaces).
    Anyway I gotta few days off so I’m pouring stuff. This 85 Tri-z throttle rubber piece was a very hard mold to make!!!! After three tries(fails) and two mold “adjustments” I finally have two in a row that are nice. Yay!!! The pocket/sleeve for the frame attach point actually worked first try. I’ll show the actual mold later today, it’s busy at the moment.
    I’m not even sure if these are sought after, I’m making 3 or 4 for a member here. But the mold is mine so I’ll probably make a few extras just in case.
    Thanks for looking (I still can’t believe the mold actually worked)
ID:	260824 Click image for larger version.
ID:	260825 Click image for larger version.
ID:	260826 Click image for larger version.
    The plastic tongue depressor is actually part of the mold, I drilled a couple holes in it so the mold material would hold it in place. There’s a metal locating pin in bottom of mold to center it(it’s working). I said I’d put a mold pic so.
ID:	260857 Click image for larger version.
ID:	260858 Click image for larger version.
    Shep
  10. #2890
    Jul 2003
    indiana
    892
    Loading out some concrete. Real yawn a minute. Guys who tore it out to "do me a favor," piled it up right under power lines. If they would have just let me do it we would only be picking this crap up once, not 3 times. Good thing I'm charging by the hour on this one
  11. #2891
    May 2015
    San Diego, CA
    1,797
    Deciding whether it's worth the work to tear into the primary now to cure a small leak or wait til later.
    Since it has nearly 101K on the clock......what would a garage with Harley Davidson's be like without some oil stains.
  12. #2892
    Mar 2009
    new england
    1,391
    Bracket done
    Just got to run the wire to switch
  13. #2893
    Mexico
    9,018
    That's it??? My Japanese stuff leaks worse than that.
  14. #2894
    Mar 2009
    new england
    1,391
    Other than the new 1 ton, everything I own leaks something lol.
  15. #2895
    Mar 2009
    new england
    1,391
    Failure by design, started mounting the doors on the Jeep after buying hinge sockets. The upper hinge was way off to start.
    I considered just making a new socket where it sat but after looking closer, not only were the upper hinges mounted low, they were on the wrong doors.
    I then noted that the lower hinges were also swapped making for a large door gap.
    So everything came apart and put together the right way
    First the lowers installed, gap fixed.
    There is a missing filler piece creating a gap at window frame, u can see where the prior owner had affixed a shim. I may use the old holes and put some flashing on for the time being.
    Doors are just for winter driveway plowing, the other 3 seasons, no doors.
    I suspect the prior owner put lower hinges on backwards first leading to further and further errors. The other possibility is the lack of the filler piece and a crazy work around
