Page 128 of 308 FirstFirst ... 28 78 118 126 127 128 129 130 138 178 228 ... LastLast
Results 1,906 to 1,920 of 4609
  1. #1906
    9,012
    Checking out this antique snowplow.
    I guess they use it whenever they get snow up the Wausau
    It sucks to get old
  2. #1907
    May 2016
    OH Canada
    1,102
ID:	253571Click image for larger version.
    Pulled it out of storage. Rear brake is dickered. Axle has play and bent. Going to toss one in the rear. Used straight axle. New bearings and seals. Also change the gearing. Up 1 tooth on the front.
    '83 200X
  3. #1908
    Mar 2009
    new england
    1,391
    Made up some linkages and hit up the scrapyard for some parts to make a runner.
    Got it spinning, a lot of afterfire and some backfire. Found the exhaust valves stuck open (common in this motor)
    So now it seems the timing is 180 off or maybe 360 as the intake sounds like the exhaust. Switching the plug wires gets the puff out the exhaust. More to do
  4. #1909
    Mar 2009
    new england
    1,391
    Ok running like a top, I have to time it, cut shaft for pto and add a generator circuit
    Running:
    https://youtu.be/O_aFDIgM5pI
  5. #1910
    May 2015
    San Diego, CA
    1,746
    Quote Originally Posted by Rob Canadian View Post
    up 1 up front should be noticeable.
  6. #1911
    stoshu is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jun 2011
    winnipeg
    242
    Just put this away for the night. Good friend wants to sell it and I live on a very busy highway. Second owner and only 30 000 kms. Yes, he said drive it as much as I want. Can’t believe how slow it is compared to my kids EVO.
    Attached Thumbnails Attached Thumbnails 888761FF-6316-40CF-98CB-8A12A3AFD620.jpeg
  7. #1912
    May 2015
    San Diego, CA
    1,746
    Just enjoying a Gurkha before the tonights festivities begin
  8. #1913
    9,012
    Mi encanta los puros!
    It sucks to get old
  9. #1914
    Scootertrash's Avatar
    In the sticks
    4,628
    What type of festivities?
    Do you wear a Burka wilst you enjoy yer Gurkha?
  10. #1915
    Mar 2009
    new england
    1,391
    Picked up a 8’x8’ chain harrow
    Fun implement for the driveway
    I probably use a crawler for exercise (for the crawler) but the old allis was able to pull the 400# drag without issue (minus steering on sharp corners)
  11. #1916
    9,012
    I’m a little surprised that you don’t have paving equipment.
    It sucks to get old
  12. #1917
    Mar 2009
    new england
    1,391
    1) I got a good laugh ^
    2) good friggin idea
    ( though I do like the gravel with the crawlers and the multiple pieces of equipment that drip oil )
  13. #1918
    9,012
    good friggin idea
    Except for the smell of the batch plant
    It sucks to get old
  14. #1919
    Mar 2009
    new england
    1,391
    Hit up the local scrap yard to get some parts for the Wisconsin engine, I wanted to add a charging circuit. $30 isn’t too bad
  15. #1920
    May 2015
    San Diego, CA
    1,746
    Good score!!
