Page 68 of 308 FirstFirst ... 18 58 66 67 68 69 70 78 118 168 ... LastLast
Results 1,006 to 1,020 of 4608
  1. #1006
    Nov 2015
    Davenport iowa
    1,144
    Quote Originally Posted by Jaywood1207 View Post
    Today was ring day in the shop. First one is a new material I'm working with and will add to my shop in the new year. Second is amboyna burl on a stainless steel core and last is a set of laminated rings using walnut and bloodwood.
    Attachment 248271Attachment 248272Attachment 248273
    Jay
    Those rings are Bad Ass..
    Sent from my XT1650 using Tapatalk
    1974 original 90 X 2
    1974 Original 70.
  2. #1007
    9,010
    Unfugled and soon to be placed into a ZipLoc bag for future time travelers to find.
  3. #1008
    May 2015
    San Diego, CA
    1,743
    WOW!!.......what a difference!!....... nice job
    Took the HD for a spin today. Nice 2 up cruiser
  4. #1009
    Scootertrash's Avatar
    In the sticks
    4,628
    Went out to hop on the 200 Snaggit to go for a spin in the woods, recoil crapped out so I had to take the Canuk for a spin instead.
    Went to the beer...er....deer stand to grab the folding swivel seat and put it back in storage.
  5. #1010
    In the sticks
    4,628
    Today, (and several days lately when I haven't been deer hunting) working on saws, overhauling most. Today it is a Husqvarna 55 for a friend. Cylinder had alot of transfer in it from a bad air leak at the intake coupler. Saved the cylinder using muriatic acid and sanding by hand. Got the saw the rest of the way torn down, cleaned and ready for reassembly today. Just waiting on parts now.
    Saw will run fine with those minor scratches that remain in the plating near the exhaust port. The flashlight and camera really amplify the severity of it. In reality they are pretty faint.
    I've got a 55 that suffered the same fate. Still sitting on the shelf waiting for attention.
  6. #1011
    In the sticks
    4,628
    Did you ever check into whether your cam chain tensioners had been inspected/replaced before you bought the bike? They should be inspected at around 40,000 miles. Not tryin' to harp on ya, I would just hate to see your engine get trashed. If you're mechanically inclined I've been told it not a bad swap. Lots of quality aftermarket options for replacement.
    Keep 'er between the lines and the signs
    ETA: Here's a link to a current thread at HDForums. Pics in the first post show how the tensioner shoe disintegrates.
    ETA2: Helps if I put the link in: https://www.hdforums.com/forum/touri...ensioners.html
    Last edited by Scootertrash; 12-11-2017 at 09:49 AM. Reason: These shoes weren't made for walkin'
  7. #1012
    Aug 2015
    Idaho
    777
    First to shoot the stem, wins....
    Little guy won!!!
  8. #1013
    Aug 2015
    Idaho
    777
    What are you doing today? Thread
    Quote Originally Posted by Jd110 View Post
    Starter quit working tonight. Fun fun!!!
    It's broken....can you spot it?
    Not sure how that happened, but I fixed this morning.
    And it's ALIVE!!!!!
  9. #1014
    Mar 2013
    Baldwin, Wi
    603
    This was Saturday. Hayward, WI. first time with the Pro Wedges in the snow and they worked awesome.
    85 Tri-z Basket Case
  10. #1015
    Blossvale NY
    4,567
    Well, those 55 are pretty solid and well built saws despite the inherent weakness of the intake tract design. It's time that is the enemy of this model, the rubber intake couple and/or impulse couple lose their ability to seal and they begin to lean out and then burn down. The upside is that being mag case construction like other "pro" models, they are worth rebuilding and not overly expensive to do if you can do the work yourself. This saw is getting new crank seals, piston, the intake parts and of course gaskets for under $100. The only part that is aftermarket will be the piston because this is the "closed port" 55 and Husky has discontinued the 45mm windowed piston for this saw. Only one game on town for the aftermarket piston, Lil Red Barn. You can get aftermarket piston/cylinder kits ranging from $25 to about $100 for the 55. Quality can be hit and miss with the ultra cheap kits though. I have a 55 "open port" model that I will be rebuilding with my boy. I took a chance on a kit that was only 13 bucks from the site sponsor of a saw forum I am a member of.
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 200ES Big Red
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
  11. #1016
    Nov 2015
    Davenport iowa
    1,144
    Bigger shop
    Contemplating a bigger DamShop
  12. #1017
    tripledog's Avatar
    Aug 2011
    Central New York
    2,183
    Quote Originally Posted by DAM shop View Post
    You may end up with LESS room with a bigger shop. Nature abhors a vacuum. As do my dogs.
  13. #1018
    Nov 2015
    Davenport iowa
    1,144
    I hear ya, $$$ of a new shop or continue to utilize the storage building out back. This works for what we do..
    Sure is nice to dream about it..
    I have considered adding onto the side of the original garage bumping it out the side 12' or so .. the price of concrete kills me, I could do the building myself.. had considered a raised wood floor instead of concrete..
    My wife seems to think I should pour the Crete this coming year and a year later add the structure..
  14. #1019
    In the sticks
    4,628
    I have no problem doing th eowrk, so I'm good there.
    How do I tell the difference between the open port and closed port models? I think I have a hybrid piston kit saved on my ebay watch list, I'll have to check.
  15. #1020
    9,010
    I think I see your problem. It's that yellow quad with the steering wheel. Get rid of that DAM thing and you'll not only have room for another trike, but your weekends will be freed up to ride them.
