Page 134 of 308 FirstFirst ... 34 84 124 132 133 134 135 136 144 184 234 ... LastLast
Results 1,996 to 2,010 of 4609
  1. #1996
    Aug 2016
    East of Worcester ma
    1,328
    Well, my pouring came out fine just wish it was steel not aluminum.Click image for larger version.
ID:	254383 Click image for larger version.
ID:	254384 Click image for larger version.
    And the splines didn’t work out.....
    Thanx for looking,
    Shep
  2. #1997
    May 2015
    San Diego, CA
    1,747
    Thanx for looking,
    Shep
    That's a good try Shep!.......
    Are the splines cast at the factory or were they like forged or something? Either way your attempts always turn out winners down the road.
  3. #1998
    Aug 2016
    1,328
    The splines are machined in afterwards, with a costly machine tool I’m guessing.
    Aluminum won’t work as a kicker if it could I’d just use the kickshaft in the sand then remove the knuckle while pouring and molten alum would form perfectly around it.(then remove) Sadly the alum would just strip out on kicking over I’d amagine.
    Tried looking on that utube, there’s not many vids on inner spline machining.
    Shep
  4. #1999
    Mar 2009
    new england
    1,391
    Ok got the charging circuit up and running on my Wisconsin thd project. Dunno what i am gonna do with the darn thing! Today, a flywheel change and putting in the stator and various rectifiers, etc.
    I am getting 34v AC off one wire and 22vDC off another, by the time it filters down it is 7-8vDC to the ammeter (2000 rpm.) Maybe this is a 6v system? Or bad rectifiers etc. this is the 3 unit system and it is hard to find anything about what I should see/read/test.
    Running video, after setting timing advance
    https://youtu.be/EIHVHJM50i4
  5. #2000
    Aug 2016
    1,328
    I didn’t think I’d get sick of looking at Honda red but I’m getting pretty close to it. Been molding since noonish, 4- done one in the mold in background and still 3 more tonight to finish/pour. I’m using the beer case as a weight the problem is it’s getting lighter as the night goes on
    Finished at midnight. Just a little clean up to do.
    Shep
  6. #2001
    3Z with Fangs! is offline At The Back Of The Pack Arm chair racerFirst time rider
    May 2018
    Virginia
    184
    Today I got the 39mm PWK on the TRI-Z. With no real tuning it's already pretty happy and that makes me happy!!
  7. #2002
    9,012
    I’m stuck on the word for the process used to make inner splines, but it’s not terribly complicated. It’s the same process that’s used to size box end wrenches after forging. It’s just a tapered tool with the shape of the splines on it that’s punched though the red hot forging. I’ll think of the name of the process, just got too much tequila in my head at the moment.
    It sucks to get old
  8. #2003
    The Open Road
    4,729
    https://youtu.be/cJZejLrCNIA
    https://youtu.be/vSmxi2224dc
  9. #2004
    9,012
    There ya go, broach is the word I was looking for, but the process I saw was much simpler. Just a broach on a vertical press.
    It sucks to get old
  10. #2005
    Mar 2009
    new england
    1,391
    Started working on a leaky swing cylinder on the case backhoe
    never done a cylinder rebuilt
    will see how this goes
    first it seems I need to upsize my tooling to at least 3/4 as 1/2 was seemingly not enough
    I also had someone come and look at the Oliver crawler. I had listed it for sale. But after driving around, I stuck firm on my price and removed the listing as it is just too much fun
    I also ripped out the garden
  11. #2006
    Cold Lake, Alberta, Canada
    3,001
    Watching the effing snow come down, that's what I'm doing today! I'm glad I winterized everything two weeks ago.
    Everyone else seems to be doing cool things but me!
    Trikes
    1970/71 US 90 (Aquarius Blue)
    1972/73 US 90 Green
    1982 ATC 70
    1983 ATC 70 (Ladybug)
    1973 ATC 70
    TF 2015
    Other
    1983 Honda Z50
    1978 Honda XL75
  12. #2007
    3,001
    Plastik, there's a lot of info on the "Smokstak" forum on old gen sets if interested. Of course I'm on there due to that old military set I have.
    Trikes
    1972/73 US 90 Green
    1982 ATC 70
    1973 ATC 70
    TF 2015
    Other
    1983 Honda Z50
    1978 Honda XL75
  13. #2008
    Mar 2009
    new england
    1,391
    Thx!
    I posted there in the Wisconsin forum hoping someone would want this beast as I started the repair
    Still stuck with it
    Maybe I will find a use
    Thank you though!
  14. #2009
    May 2016
    OH Canada
    1,102
    Took out the XL250R today. I put in a new clutch and did some maintenance to it. Had a hard time starting it... It took 2 kicks. Usually starts on first kick.
    Runs great. Should have done the clutch earlier. What a difference.
    '83 200X
  15. #2010
    Jul 2003
    indiana
    891
    I was having some issues with my drill press, darn thing wouldn't drill through 22 gauge without bogging out. I fiddle farted around with it and didn't get anywhere. While working on something else it came to me, check the driven pulley! Gosh darn set screw was boogered up. Got my tools out, re aligned the pulleys on the shaft and tourqed it down, good for another 100 years I bet! Use to be a line shaft machine, I converted it to electric motor drive. Now I have some hit n miss motors, time to assemble a line shaft system!!
