Page 205 of 308 FirstFirst ... 105 155 195 203 204 205 206 207 215 255 305 ... LastLast
Results 3,061 to 3,075 of 4609
  1. #3061
    Manheim, PA
    5,754
    I had it straightened then coated. Either it was not straighten enought or it sprung back. Bought a new frame last night, visually straighter and installed all my arms just to check and still have 1/2" off between front ball joints. Arms are straight, triple checked them. There is 1 more frame I know if to check against these two I have now monday. I'm so over this blaster project and sad part I was done! I really think their fixtures were not stright. My 1990 frame is longer then my 2002. Nothings even close to being in same spot. Which is fine but I dont think I'd want a 1/2" off between wheelbases from either side.
    I find is highly unlikely two different frames bent at the exact same place per side. I'm use a tape measure from flat garage witch everything tightened on bike. I stood it on end. I guess 1/16" where a arms go could turn out to be 1/4" at end of a arms.
    Not much seems to be welded in stright between the two frames either. Maybe OEM frames are ok with +/-.125 inch or more. The area where I think the bend is taking place is where the exhaust swoops down behind the left front a arm...but I can't see it giving off that much heat to tweak. One frame I had was in a bad crash. The spindle was bent and frame was really bent. I had that one straightened and gussested up.
    The pic is of my 2002 straightened frame. My 1990 one is green frame.
  2. #3062
    House Springs MO
    5,496
    Tearing appart a blaster I just built. Straighten frame warped under temps from powder coating.
    I'll take "shite that never happened" for a $1000 Alex.
  3. #3063
    Slidell, LA
    4,737
    Tearing appart a blaster I just built. Straighten frame warped under temps from powder coating. Now to mod a new frame all over again. Talk about a setback. Tweaked frame may become a 3wheeler now.
    That’s impossible. Use a new company to straighten your frames.
  4. #3064
    9,011
    That's what I was thinking as well.
    Can an oven warp a frame?... I've never had that happen before.
    Not a powder coating oven. Stress relief oven is another thing, but no one in their right mind would ever try to get those kind of temperatures into a powdered oven.
    I can swear to the fact that factory frames don’t always come straight. That goes for aluminum frames too.
  5. #3065
    Manheim, PA
    5,754
    Hre did it. Normally hes dead on. Which after today's messing around with my other frame everything checks out but is still off the same distances. I had hre straighten the bad gray one. Visually I didnt care what it looked like, mechanically I wanted it stright. He has another blaster frame I'll check out monday. If 3 are off the same then it's not bent, it's how the factory welded them in. I know 200x and 250r frames never had one the same between a few. I helped hre come up with his fixtures to reproduce atc250r frames. I've seen that 1st hand. Just blows my mind that a company would sign off on frames allowing 1/2" differences between left and right wheel bases. I measured my a arms 3 times this afternoon. Either way I'll be converting my green frame to run a trx450r brakes and replicating what I had done to my gray frame. I'd rather start all over and try again then use the visibly bent frame that was welded into a fixture and straightened. Blaster trike will be made out of my titled gray frame. I didnt even want this project but figured let's built one with all my spares from parting. You all know that feeling.
  6. #3066
    Aug 2016
    East of Worcester ma
    1,328
    Before/after- limited time and weather a couple 50 degree days only at noon time to prime/paint outside. 4-days probably 12hrs. Not 100% perfect but the elec bikes getting a metal tank and I found/ordered a gps speedo that by online measurements should fit nicely in the filler hole, two power wires fed out the petcock? Hopefully, guess I’ll find out soon
    Before
ID:	261762 Click image for larger version.
    During
ID:	261765 Click image for larger version.
    After
    Damn I hate painting tanks/ but it’s DONE!!
    Thnx for looking
    Shep
    Was going to use a different tank but it was going to take twice as much work.
  7. #3067
    9,011
    Before
    During
    After
    Thnx for looking
    Shep
    Nice!
    Now all you need to do is route refrigeration tubing inside it, plumb in a compressor and it can be used to carry cold beer. Might be a little foamy, but still a delightful treat out on the trail
  8. #3068
    Aug 2016
    1,328
    I was thinking fill it with some kind of “refreshment” and use the fuel shut off for a tap.
    Or some kind of pressurized flame retardant Incase my lithium battery ever explodes....
    Shep
    Just kiddin’
  9. #3069
    The Open Road
    4,729
    That tank looks fantastic Shep
  10. #3070
    Aug 2016
    1,328
    Thanks chop, I think I sanded off most of my fingerprints doing this tank though. Click image for larger version.
    Now for tank fins—- hmmm
    Wonder if there’s orange fins out there somewhere.
    Shep
  11. #3071
    The Open Road
    4,729
    Shep
    As soon as you make some, yes there will be lol
  12. #3072
    9,011
    Can’t wait to try out that zinc Shep.
  13. #3073
    Nov 2015
    Davenport iowa
    1,144
    Weather people.
    Just once I would like to have our Weather people say “ we have snow coming we are not sure of the amount, we’ll let you know as the storm approaches “ dumb arses. How things go from having a winter storm warning yesterday ( for tomorrow’s weather) to not having one today.
    Sometimes I feel like I’m living in a black hole thinking to myself did they predict that or did I just imagine they did because people can’t be that bad at their stinking jobs.
    Oops meant to post this in the What pisses you off thread
    1974 original 90 X 2
    1974 Original 70.
  14. #3074
    May 2015
    San Diego, CA
    1,743
    God I hate changing the water pump on a van. I should have paid somebody to do this.... Pain in the rear end
  15. #3075
    Aug 2016
    1,328
    Tank speedo- this gps unit has no external antenna but all the reviews were good except a couple that claimed it didn’t work unless it was aimed (speedo face) straight up. Well that’s what I have
    Think I’ll stick her on the truck passenger seat w/me today just to see.
    Problem is it’s power is anywhere between 12-24v, I think the bike motor controller has a 12v output (not enough amps to run the headlight off it). but this doesn’t take much juice.
    Fits snug, top is waterproof supposedly but I think I’ll put a thin 2” oring between tank/speedo.
    Think I’m done writing SPEEDO - all that comes to mind is those “grape smuggling” bathing suits (not a good vision)
ID:	261804 Click image for larger version.
ID:	261805 Click image for larger version.
    Shep
