not easy on the throttle,,, smoooooooth on the throttle.
like they say,,, slow is smooth and smooth is fast,, er something'... just don't direct pin it cold and you should be ok.
Wubba Lubba Dub Dub!!!!!
TRIKES:
86 250r
85 250sx
86 250sx
85 Yama 225DX - The Rental!
150cc Piranha powered 70
110cc Lifan 70
82 70
83 ALT 50 Trail Buddy
88 Yamaha BW 80
84 z50
You should be able to nail it.
Is the air filter box closed up or does it have any holes in it?
What exhaust are you running?
No air leak if you spray around the intake while it's running?
I'm gonna weigh in here too for sending to Jim and let him do his magic on it OR follow his advice like I did (cause I'm a cheap ) and drill out your starter jet and this will help a bunch in cold starts!! I am in Michigan and even when it's fifty degrees I need to use the "choke" and then a little throttle and feather it a bit. I can definitely relate to the lack of finesse with a throttle but am learning;;;;; I think. I should also add that even after I have run it till I KNOW that the engine is warm and then shut it off for an hour I (may) have to duplicate my cold weather starting procedure. I now have Two 250sx's and a third that belongs to a buddy and ALL THREE do EXACTLY the same thing you are saying; if I am following correctly. Once these are warm like Speedgoat says you should pretty much be able to nail the throttle and get instant acceleration!! Good luck, Walt~
