Results 1 to 10 of 10
Thread: tri z electrics conversion
    Oct 2011
    Manchester england
    135
    hey guys, having some issues with my 86 Z.
    cut the story short, throttle wide open at top end, the bike desides it wants to stop sparking. ive put a a new ignition coils on from the stator, we wired the loom, changed coil, ht and plug, the only thing i havent done is cdi. ive have no access to another to try and i dont want to buy an old second hand one so im looking for new. but im assumeing they need to be set to my bike???
    question being is there a bolt on full stator kit from another bike that will fit?
    DONT DO QUAD ROIND HERE! Live fast or die trying
    3 wheels for life
    86' Tri z converted back from a quad
    86 Tri z in bits
    Banshee ready for the chop
    04 cr 250 with vforce
    Tri zinger
    Crf/yx140 mini motox
    Jincheng 50 for those drunken evenings in the feild
    Race van
    Shogun
    And a hot tub for after a days ride! Yehaaa!
    Jan 2014
    Prescott az
    685
    There's a thread that shows all the parts that interchange with the tri z but I don't remember​ anything that has the same stator
    [/SIGPIC]
    85 350x
    83 200x-sold
    ×2 85 200x-sold
    06 kx250f-sold
    86 tecate-sold
    86 tri z powervalved
    85 BIG red
    18 rmz250
    87 lt80
    19 ttr110
    Oct 2011
    Manchester england
    135
    yeah ive checked that but nothing regards electrics unless i mist it
    3 wheels for life
    86 Tri z in bits
    Tri zinger
    Race van
    Shogun
    Oct 2011
    Manchester england
    135
    bump. anyone??
    3 wheels for life
    86 Tri z in bits
    Tri zinger
    Race van
    Shogun
    Jul 2012
    Seattle, Washington
    1,544
    There is no bolt on replacement from any other bikes that I know of.
    Oct 2011
    Manchester england
    135
    someone must have had to buy a new cdi for a tri z at some point.ive found one from electrex that states "universal" but cdi's are designed for specific bikes if im not mistaken. a nice mappable cdi would be nice to find and ill map the curve myselve on the dyno but again, trying to find one of those is becoming near impossible
    3 wheels for life
    86 Tri z in bits
    Tri zinger
    Race van
    Shogun
    Oct 2011
    Manchester england
    135
    anyone found a pvl ignition? ive just come across that this is what i want
    3 wheels for life
    86 Tri z in bits
    Tri zinger
    Race van
    Shogun
    Apr 2012
    USA
    4,114
    You shouldn't need another stator as long as the CDI design is the same (ac vs dc, voltage range might be a thing too). The advancement curve is based on per machine, but internally its a capacitor from memory that's resized for the desired effect.
    The service manual I have actually shows the advancement curve, never seen this info in a Honda service manual, so it stuck out to me. Not sure if you'll need to find another 2 stroke cdi or if 4 stroke has a similar advancement curve.
    If you find a modern cdi that works, you'll likely have to rewire your main harness for the 4+2 style cdi plugs if your machine didn't come with them (seems they started around 85-86 era on Honda's). The wire diagram shows that the CDI does get regulated 12v power, pretty sure it's AC based though (no rectifier). I don't know the Yamaha's well enough to suggest possible sources for a "new" or upgraded CDI, only thing that comes to mind is a blaster since it's 250cc and 2 stroke.
    Jul 2012
    Seattle, Washington
    1,544
    I saved these from somewhere on 3ww:
ID:	241116Click image for larger version.
ID:	241117Click image for larger version.
ID:	241118Click image for larger version.
    Apr 2012
    USA
    4,114
    Yea those are from the same service manual that I have. First pic is page 114 of it. Been collecting service manuals because of my wire harness reproduction stuffs.
