Can someone please tell me on a 1986 Tecate where to connect the ground wire that comes off the igniter, also where does the ground go that comes off the wiring harness, thanks guys just trying to get all the electric sorted out.
I'm in the same boat with my tri z but can never really get any wiring questions answered.
[/SIGPIC]
85 350x
83 200x-sold
×2 85 200x-sold
06 kx250f-sold
86 tecate-sold
86 tri z powervalved
85 BIG red
18 rmz250
87 lt80
19 ttr110
Bueller? Bueller?
Fry? Fry? Haha
[/SIGPIC]
85 350x
83 200x-sold
×2 85 200x-sold
06 kx250f-sold
86 tecate-sold
85 BIG red
18 rmz250
87 lt80
19 ttr110
I don't know anything about the 86/87 T3 but the 84/85 T3 grounds everything at one of the coil mounts.
The ground that comes out of the bottom of the coil mounts under the low side of the coil--it only runs about 1 inch. I put it between the "bar" (sticking out of the bottom of the coil) and the frame. Make sure you have metal on metal contact. From what I remember, the ground coming from the stator connects to the CDI. There is another wire that comes out of the CDI and attaches to the bottom of the coil (it has a flat clip so it should be obvious).
Well, kinda. The single wire coming out of the stator attaches to one of the single wires coming off the CDI (OEM uses a round bullet coupling). Next, the 3 prong plug off the stator also attaches to the CDI. Then you have one more wire coming out of the CDI--with a flat clip--that attaches to its counterpart on the underside of the coil. Lastly, the short wire coming out of the coil grounds under the lower mount for the coil.
