Page 2 of 2 FirstFirst 1 2
Results 16 to 17 of 17
Thread: Got some work done!!!
    Feb 2017
    New Britain, PA
    67
    I have a weird noise now! It's a sweeky swirly noise from clutch side like the bearing that is pressed into the clutch case is dry. It's not dry there is oil in the case. It goes away when I shift from n to first or into any gear and when I idle in gear it's gone! When I idle in neutral and when I'am under power in gear I hear it. Also if I slightly press the shifter down like just a little bit it goes away. Maybe that bearing is beat? Anyone have any ideals? Clutch grabs good and seems to shift fine reverse is fine? Pissed off not sure where to look first other then pulling off clutch cover and seeing if anything looks worn, just didn't want to burn another 20$ on a seal that are getting hard to find!!
    Sent from my iPhone using Tapatalk Pro
    Feb 2017
    New Britain, PA
    67
    Had it for a little test drive today, have new front fender on, but don't have all the new plastics back from hydro dip yet!!
