Yes that is the challenge, positioning the rotor.
But I don't think it's impossible, especially given the offset of the wheel. Flipping the rim over from its normal position will place the rotor closer to the fork leg.
So in effect, the hub will not be central on the axle, but this will not be an issue as long as the the tyre tread is central to the axle.
I'm so looking forward to completing my mini trike conversion to test this theory.
Sent from my iPad using Tapatalk
My toys 85 KXT250A2, 85 ATC250R, 85 Tri-z 250, 06 LT-R450, 04 YFZ450S, 07 125 typhoon x 3, 06 FPV GT.
All you can do is try.....
Here's my front brake setup using vtx triples and yz forks. I used a late 200x front hub and rotor and kx80 front caliper. I machined the hub so I could run the wheel on the other side in order to get it centered. Also made an adapter to attach kx caliper to yz forks. So far works great. Yamaha xs 1100 rear axle with slight modification is almost perfect for front axle when using yz forks.
Plevib, the xs axle is the correct length and diameter for the yz forks, I had to turn down the big end of it slightly so that it would clamp in the forks. Also had to change the bearing in the hub to a 42x20x12mm bearing to fit the larger axle.
Kasey, is there any chance you could describe the machine work you had to do with the 250r hub? That is the route I am planning on trying first. I've changed my direction on the swingarm. I am going the yfz route, trying to figure out how to use the bushing that is on the outside of the crf bearings to help preserve the frame. With the dust seal it's bigger than the yfz tube. Someone please tell me if I'm crazy, but I'm considering cutting the front of the crf swingarm off, just the tubes that the bolt goes through and then welding it to the yfz after cutting the front tubes off of that and trimming it to the same width. Is that going to cause strength problems?
ATC 70
ATC 110
Yamaha 225DX
ATC 185s
86 ATC 310r
So, progress, I'm having Tyson Racing do a custom swingarm crf holes for the pivot bolt to go through, +2 of a yfz from there to the bearing carrier housing, and trx housing. That should be here this week. Working on the front end, pressing the steering stem out of the crf was a bear, but it's now in the lower vtx triple. ground off the vtx steering stop and the key lock. Will have to put steering stops back on once it's more together. The top triple is a mm too big, so I've got shim stock to fill that. Better ideas welcome. The bottom triple is a mm too small and won't spread that far. It is getting bored. On the axle, I'm having a busing made 2 1/2 inches long the inside diameter of a 250r axle and the outside diameter of the fat end of the crf axle. the fat end of the 250r axle is the same diameter as the small side of the crf fork hole, so no it'll just be a matter of cutting bushings and spacers to center everything. I'm using the 250r brake disk and cutting it down for my adapter to fit the crf brake disk. Looks like it should work well. My other option was to have a new plate made that was the diameter of the crf with the center of the 250r, but I thought having an extra little bit of room for the brake caliper would be a good thing. I am using a Douglas 11" rim. Definitely feeling the pain of not having my own machine shop, and the ability to weld aluminum.
ATC 70
ATC 110
Yamaha 225DX
ATC 185s
86 ATC 310r
Current Trikes:
85 350x
P3 (x2)
Quads:
2003 Polaris Predator 500
1988 Yamaha Warrior
2003 Polaris Predator 90
Previous Trikes:
84 Honda 110 (parts)
85 Honda 110
85 Honda 200x
87 Honda 200x
85 Honda 250sx
KX 80 Trike conversion
Gone and missed:
Here in my 2008 450x trike front end. I had triples made instead of using vtx triples. It does cost a but more but you end up with a nice setup. 10 inch wheel and 250r hub. Waiting on a custom swingarm for the rear.
I'm glad you just decided to buy new clamps. Most cast fork clamps are difficult at best to clamp down and set up for boring.
And if you buy a TIG for aluminum, try to take a class or get lots of 6061 scraps to practice on. I still wouldn't do any critical aluminum welding; I'm just not great at it yet and I need more practice....
Update, my swingarm arrived yesterday, so I will be starting the assembly tonight hopefully. I have to figure out my bearing situation, because it doesn't have the wider outer section of the front tubes like the crf does, it's more straight like the yfz, so I am hoping that a combination of the crf and yfz parts will fit together. I'll be stopping by the local Yamaha shop this afternoon to look things over.
ATC 70
ATC 110
Yamaha 225DX
ATC 185s
86 ATC 310r
So, the only things that are the same diameter between the yfz and crf are the inside of the bearings/outside of the collars. The crf bearings outside are a mm larger than the yfz and the crf pivot bolt is larger than the yfz pivot bolt. So, Since my swingarm is based on the yfz front, just the width of the crf, I'm going to use the whole yfz setup. I don't have the yfz pivot bolt yet, so I'll let you know what will need to be modified there when I get one.
ATC 70
ATC 110
Yamaha 225DX
ATC 185s
86 ATC 310r
