Results 1 to 9 of 9
Thread: Powder coating gas tank questions
    Dec 2002
    salem, nh
    1,339
    I red koted the inside of my atc70 gas tank 10 years ago but I'm rebuilding the trike and will be powder coating. My question is do I need to remove the coating with acetone before they powder coat it? And if I have to remove it what can I do to prevent it from rusting while they do it? I'd hate to put muriatic acid in it to etch it and get it on the coating.
    Second is I have a dent on the front of the tank from the steering stop being bent and the forks going too far and hitting the tank. How can I fix this so it can be powder coated? I don't think I can use bondo so what do I use? Jb weld? Real weld?
    85 250SX New to me!!
    85 ATC 70 stock ~ TRADED
    85 ATC 70 with 138cc Lifan
    83 110 restored ~ sold
    85 110 restored ~ sold
    83 200x restored ~ sold
    02 400ex ~~~SOLD
    K&N filter
    K&N jet kit
    EHS Racing lid
    Removed choke 42 pilot DJ146 main
    HMF full exhaust
    AC skids
    Holeshot XCR rears
    14t front sprocket
    IMS Roll front bumper
    Graydon Proline nerfs
    All I can tell you is PC is usually 375 - 400 degrees.
    I'd ask Red Kote if it can withstand that heat for up to 20 minutes.
    Pekin IL
    529
    I have shot over jb weld with good results but i put in on pretty thin. A really good local coater suggested something called metal-lab as a filler but it really need to be put on thin also.
    Sent from my SM-G935V using Tapatalk
    1985 250r
    1985 200s
    1984 200x
    bandito x2
    1979 atc70
    Trikefest 2012,13,14,15
    Dec 2002
    salem, nh
    1,339
    It says in their instructions it will turn to ash if heated above 250 degrees. Guess I'll have to remove it
    02 400ex ~~~SOLD
    K&N filter
    K&N jet kit
    EHS Racing lid
    HMF full exhaust
    AC skids
    Holeshot XCR rears
    14t front sprocket
    Scootertrash's Avatar
    In the sticks
    4,628
    How big is the dent? Got a pic? Put something next to the dent for a size perspective, like a dollar bill, pop can, quarter, etc.
    NEPA
    7,048
    Paint it and have it right. Life is short.
    Sep 2007
    Calgary, Alberta Canada
    23
    I use lab metal for the dents. Powder will be attracted to it but it can only be heated to 400 degrees once, unless you buy the high heat type. Lab metal does seem to shrink a little. I have used jb weld on smaller dents but you have to hot flock the part.
    Dec 2002
    salem, nh
    1,339
    Decided to have my buddy fill it with weld so it's done correct
    02 400ex ~~~SOLD
    K&N filter
    K&N jet kit
    EHS Racing lid
    HMF full exhaust
    AC skids
    Holeshot XCR rears
    14t front sprocket
    Dec 2002
    salem, nh
    1,339
    Banana for reference
    02 400ex ~~~SOLD
    K&N filter
    K&N jet kit
    EHS Racing lid
    HMF full exhaust
    AC skids
    Holeshot XCR rears
    14t front sprocket
