I understand your search for answers and help, it can be frustrating, but ultimately you have to dig into it to see what's going on.
Upon further thought.. I do suppose,if you pull the clutch cover,and have a dowel very close in diameter to the counter shaft, you could fish it through the kick starter and follow the CS out ,capturing all of the gears and washers . Either way,seems to be one i haven't run into... The worst noise in that vid halfway through,sounded like a bad rod.. But the rest , I couldn't make sense of. Keep us posted please.
I will keep your posted for sure, that different side gear comes in today so I'll try to get it installed without loosing parts in the case. If that don't work then guess I'm pulling the motor and digging in.
Ouch........
Criminy! See what you can find with a little digging? I have a spare bottom end here that needs to go. Where do you live?
I live in southeast Iowa but pm me maybe we can figure something out.
Does anyone know if the transmission gears are the same between a 85 250sx and a 87 250sx?
Tope ends are the same if you sit your cylinder on up on the cases.
I found the gear set I need but it's from a 87 so wasn't sure if it would work in my 85 bottom end or not.
Parts should be here the end of this week. So hopefully will have the ol girl going again by Monday or Tuesday
New gears in and everything's back together,as long as the rain holds off tomorrow I should be able to install it and fire her up
First try was a fail, but I got it together for the 2nd time and will try it again as soon as Iowa decides to stop being the tropical rain forest and raining every single day.
