Thread: Tecate Guys!! After Market T3 Tecate rear sprocket
    dabody69 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Dec 2014
    chicago
    249
    For Guys not running stock front and rear sprockets can you make a few suggestions of some high quality aftermarket ones, thanks guys
    Arizona
    844
    I really like the sprockets from PBI. I've order 5 or so from them over the years for various machines, including my Tecates. They make a high quality aluminum rear sprocket in the size you want for around $65. Others might recommend Sprocket Specialist, but I've never ordered from them and the last time I checked they were more expensive on the sprocket I wanted. Here is PBI's website:
    http://www.pbisprockets.com/
    Oct 2006
    Wapakoneta
    815
    Sprocket Specialists is who I use. They will make you virtually anything.
    Sep 2005
    MICHIGAN
    2,026
    My last Tecate had Sunstar steel 16 tooth front (kx250) and 37 tooth rear with a 86 kx250 motor,flywheel, and trans, it ripped. The top end speed and pull even from the bottom was the best I ever rode.
    86 T3
    84 T3
    86 KX250
