I'm wondering why ATVs don't have a lower rear chain guide like a dirtbike.
I thought maybe it's because they have skid plates but those aren't designed to guide chains either.
Anyone know the answer?
I always wondered that myself
Maybe there's not as much suspension travel/geometry change, therefore no need for a rear guide to keep the chain on?
Maybe its there on a dirtbike to keep your tattered pants leg from going into the sprocket after it gets caught in the chain.
Maybe trikes don't have them because there is pecievably less of a chance of a catastrophe happening when the chain jumps and wraps around the axle on a trike as compared to a dirtbike.
Just speculation...
Suicide Hill Survivor
The rides:
1981 ATC110
1982 ATC185
1983 ATC185s
1984 ATC200es
1985 ATC200x
When the going gets tough, the tough get sideways
The Tri-Z has one.
I've always assumed that they acted as protectors of the sprocket, guides for a chain that might be getting a little loose and as a way of keeping unwanted things out of the sprocket. There are stories of road racers that have lost their toes to a rear sprocket.
The only downside to having one is they can get bent off to the side and some limit your gearing choices a little. but others like the KTM dirt bikes have multiple positioning holes..
Banshee has one too. I always thought they were a good add
If I recall correctly, the A1/A2 Tecates had a chain guide of sorts, possibly even the B1/B2's as well.
I never saw them as guides so much as guards to protect the chain and disc brake. They were one of the worst design features of the Tecates as they lasted all of 1 or 2 rides before they took a hit and bent. They needed to have a full skid plate with some heavy gage aluminum or steel.
