hey I removed the axle nuts from my 84 r but I had to cut a groove in them and chisel turn them. I bought used ones off of ebay but they are .1mm smaller in diameter on the inside than the old ones so they will not work. I looked on rocky mountain and they say there are two different part numbers based on the serial number and the serial on mine is the one you cant buy. does that mean there are two different sizes? I wanted to know if anybody had the same problem and if there is a different bike axle nut that worked for them. thank you in advance for any help.
