Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 40
Thread: 350x carb issue
    Oct 2012
    Elma NY
    59
    350x carb issue
    Hey guys,
    Been a long while since I posted, but I just got my first 350x and having some carb issues. It's an 86 w an 85 motor and 86 carb on it. Not sure if that's an issue or not. When I bought it, the throttle cable was not routed right so it would surge when turning bars and gas was over flowing from carb. But it ran and drove ok.
    Guy gave me a carb kit and recommended rebuilding, so I did. I think the carb kit was for an 85 tho based on the style of the a/f screw. After rebuild it started right up and idled nice. (Did not take apart the choke assembly). No issue w throttle cable. Let it warm up took it for drive around the block. Half way through my drive it was idling high or it wouldnt idle down when I clutched/shifted. I got it home and went to kill it w the choke (kill switch not working) and when I choked it all the way it surged up and was revving wildly. I dropped the choke and tried again. Noticed that when it hit the middle position it would start to bog as expected but as soon as all the way choked it would rev again. I shut gas off and waited it out till it died. i turned gas back on and let it sit and gas was over flowing out the carb again. Another thing to note is my idle screw is backed out pretty much all the way. Bike idled at a decent rpm there, but I thought that was strange. Also, I backed the af screw out 1.25 turns as per some write up I found on here for the 86 carb.
    So, where do y'all recommend I go from here? Should I buy the correct carb kit and rebuild? Should I tear it down again and open up/clean the choke assembly? Or should I mess w adjusting the a/f screw. I made note of the af screw position when I took it apart. It was 2.25 screws out I believe. Or should I bail on this carb and try another. Any help is appreciated. Thank you!
    May 2009
    S.E. Michigan
    1,250
    The overflowing fuel is due to your float not working properly. Lots of things could be going on:
    - The needle could be getting hung up
    - The seat might not be clean or has a nick/burr
    - The float may not be floating (hole, bent, too much crud stuck making it heavy).
    All your other settings will be out of whack if your fuel level in the bowl is off.
    Did you save your old parts? The reason I ask is that I've seen incorrect float needles before that are too short. Compare your old float needle with the new one. Also, to check your float height. To do this, hold the carb in your hand with the float bowl removed. Hold the carb sideways so that you can carefully move the float and check when it just starts pushing on the spring loaded button on the float needle. When it just starts to push on the needle, the float should be parallel with the float bowl mounting surface.
    - Frank
    1984 200ES Big Red
    1985 350X (x2)
    1986 350X
    1986 250SX
    1984 Auto-X
    1984 ATC70
    1985 ATC70
    Feb 2017
    Corona CA
    808
    Toss your factory carb and buy a 400ex carb. New there 150$ and used even cheaper. You'll need a throttle a cable also but fairly cheap. Great upgrade on even a stock to mild bike. Larger, accelerator pump , easy to find parts etc. starts easier runs harder fits with very little struggle.
    Oct 2012
    Elma NY
    59
    Thanks for the responses guys. I'll tear it down another time and try wonderboy's suggestions first. If I can get her to run right I'll take it for now. I heard the 400ex carb is a nice upgrade so I'll definitely do that at some point, especially if the stocker won't work.
    As far as the 400ex carb, does it work out of the box? Or do I have to rejet it or something?
    Feb 2017
    Corona CA
    808
    Quote Originally Posted by chasemanmusic View Post
    Hard to tell. My motor is very mild. Once over wiseco. Mild porting full exhaust stock cam. I only went up 2 jet size and I think two pilots. I know my mAin is a 148. Forgot the pilot. I think the 400ex stuffs a lot more fuel because of the accelerator pump so the jets don't have to be huge. I run the air box lid also so I might be able to get one more main .... but I would start with one size over what you have in your factory carb (OEM was 138 so maybe a 142...) unless you have more mods. But it's a good place to start.
    Oct 2012
    Elma NY
    59
    Ok i need to brush up on jet size terminology, etc.
    i dont know anything about the internals on the trike as far as mods. I do know it has a dg pipe, not sure if full, looks like only dg silencer and stock header as the header is not chrome like the silencer. Also airbox has holes drilled in the lid, which im not sure if thats considered a mod or not.
    Oct 2012
    Elma NY
    59
    I
    Figured id post a pic
    Oct 2012
    Elma NY
    59
    Apr 2014
    Edmond, KS
    2,537
    Just use the jets from the 350x carb in the 400ex carb. That's what I did and everything works great. I can't remember now if the 350x carb has a round slide or not. If it does, did you accidentally put it back in 180 degrees off? It will idle high and won't idle slower at all. If it's doing this, then it already has extra air going through the carb. Choking it would add more fuel and then could certainly run faster. I'd check that first. Not trying to turn you off of the 400ex carb swap, but my suggestion won't cost anything but time.
    Oct 2012
    Elma NY
    59
    Wow good point. Yes its round but i didnt notice a difference in which way it would go like the carbs on my 200x and 185. Those have a clear direction but i think you might be right.
    Im hoping to have time to tear it down tonight and test again. Ill follow up tomorrow.
    Thanks again to you all.
    Oct 2012
    Elma NY
    59
    Yea the throttle thing is symmetric either way you put it. Main needle looks really close in size. Different numbers on it tho
    Oct 2012
    Elma NY
    59
    Would an air leak cause behavior like that? Plug looked alright.
    Apr 2014
    Edmond, KS
    2,537
    It possibly could. That would be worth a look, too. Now my story about throttle cable routing. I had an independent shop put a new throttle cable on my 350x in 2003. The next weekend, a friend and I went out of state for a weekend ride. Everything was fine until I climbed a hill with a sharp left hand turn at the top. I came up in second gear, let off the throttle, and turned the bars left. Unfortunately, the trike revved up hard and we both went straight, hit the berm at the turn and it flipped over on top of me. With the 350x carb, the only time the stupid thing would idle was when it was upside down on top of me. This was one of the two times it idled, still in gear. Since we were riding sand trails, I was running my old Blackwater tires that I use in the sand as "semi paddles". So the right one was chewing up my right leg and I had the hardest time reaching the kill switch. After I shut it off, pulled myself out from under it, and got it back down the hill, of course I had to kick it for a LONG time to start up again. I figured out that it revved to about half throttle when turning hard to the left. I took it back to the guy the next week. He told me that his assistant had out the new cable on, but there was no was it could be on there wrong because there is only one way to route it. I was not happy with that answer. I pulled the tank off myself and sure enough, the cable was routed wrong. There was even a mark on the under tank insulation that showed the right way to run the cable. After I put it back on the right way, I never had that problem again. I also never went back to that guy again!
    Oct 2012
    Elma NY
    59
    I got the carb straightened out i think. I found the rubber plug ended up falling out of that one jet. I removed it. I also found the third time i rebuilt it that I didn't tighten the jets enough and one fell out in the bowl! Never had that happen. So i buttoned it back up and no more over flow. But it was still racing and found it was my throttle cable routing that was holding the idle open. After messing w that for a while the idle adjustment works as it should.
    So i took it out today and it rode nice. Good power, but a little popping from exhaust when letting off throttle. It has a full dg pipe. Is that normal? Also the air box lid is drilled out.
    I pulled the plug after it cooled down and found it was a little white looking (lean). So should i jet it up? Or can i simply adjust the idle/air screw to allow more fuel?
    Oct 2012
    Elma NY
    59
    Oh and one other question: the butterfly and the slide sync- are they supposed to operate in sync? As it is now the butterfly moves then the slide engages
