Results 1 to 15 of 15
Thread: carb questions 1989 atc 110
    Jun 2017
    newnan ga
    6
    just recently got into the atv game with a 1989 honda atc 110 an older gentleman across the way gave to me. it had been sitting in his backyard for quite some time and when he gave it to me i threw some fuel in it and it fired right up. only problem is it is leaking fuel from the exhaust now, like pouring out,and wont stay running. A buddy told me it was probably the carb, got online to buy a new one and noticed that the year ranges listed end in about 1985 to 1986 or so. So i guess my questions are 1. is it my carb? and 2. is there a difference in carbuerators between 1985 and 1989 honda atc 110s?
    6,726
    The last year the atc110 was made was 1985 .
    All year carburetors will work, the only differences were the fuel filter location .
    Jun 2017
    newnan ga
    6
    appreciate it, went back out and looked again, its an 83, for some reason i had myself convinced it was the same year as my blazer lol. is there any significance in the blue atc110 vs the red ones? all ive seen online are mostly red, mine is a nice blue color
    6,726
    The blue ones are a little rarer .
    Jun 2017
    newnan ga
    6
    so is it the carb do you think? i was reading somewhere that it will happen when the float is sticking, i pulled it apart and cleaned it all up really well, but it didnt seem to help any, i just went ahead and ordered one off amazon with an air filter included, figured it couldnt hurt to replace it anyways
    125Mmadness's Avatar
    125Mmadness is offline At The Back Of The Pack Arm chair racerFirst time rider
    Apr 2017
    McConnelsville,Oh
    157
    Did you check the size of your jets, I've never seen an over-fueling issue so bad that fuel poured out of the exhaust. stock main jet is 88 an stock pilot is 35.
    1985 ATC125M: Parts
    1985 ATC200S: 84 200S Bottem end, 200x Head, 200x Carb, S&S Cycle Exhaust, Wiseco 10.25:1 Piston, Reground Cam with About 1mm more lift(unknown specs).
    1988 TRX250X
    1983 ATC200E: Total Pile.
    "Bout Tree Fiddy" Master of Thy 22RE
    Jun 2017
    Lake Wales, Fl
    31
    I would adjust the carb to factory specs and see if it helps. Maybe the mixture screw is way too rich. You may have a float problem and check to make sure the bowl vent is unclogged and hanging down. I had that problem with a 200e the vent was ran up by the handlebars and the float was broken. Also if it won't run, make sure the exhaust valve isn't stuck.
    Jun 2017
    newnan ga
    6
    Quote Originally Posted by 125Mmadness View Post
    how would i go about checking the jet sizes?
    Jun 2017
    Lake Wales, Fl
    31
    I doubt even the biggest jet would let that much fuel through without some other issue.
    Apr 2017
    McConnelsville,Oh
    157
    Quote Originally Posted by natediggity View Post
    Take the jets out and look on the perimeter of them, there should be numbers stamped on them
    1985 ATC125M: Parts
    1988 TRX250X
    Apr 2017
    McConnelsville,Oh
    157
    Quote Originally Posted by BigCountry86 View Post
    Yea, I know but it could be assisting to something else
    1985 ATC125M: Parts
    1988 TRX250X
    Jun 2017
    Lake Wales, Fl
    31
    How long will it run for?
    Jun 2017
    newnan ga
    6
    when i first fired it up i (stupidly) drove it about 3/4 of a mile around my neighborhood, it shut off just short of my driveway, since then ive managed to get it to run for a minute or so until it starts flowing from the muffler and soon after that it shuts off, i think its flooding the engine.
    Jun 2017
    newnan ga
    6
    all this stuff is new to me, im used to working on lawn mowers and go karts a bit, i do most of the work on my k5 blazer and my wifes car, but im not used to these motors and problems, ive got a 4 stroke pit bike i just got with no compression, cant even figure out how to take it apart, or find any info for it online.
    Jun 2017
    Lake Wales, Fl
    31
    Most pit bikes if it is Chinese is a honda clone. You should be able to find plenty of info for working on honda motors. On the 110, you can get a brand new carb for less than $30. I would order a carb.
