185s 13 tooth sprocket
Can someone confirm if you can or can not run a 13 tooth sprocket with the case saver on a 185s? I've heard both.
1. 83 185s: (the money pit) xr200 cam, 200cc cylinder, 10.25:1 piston, 83 250r front end, 450r hubs, full suspension
2. 85 Big Red 250es: in pieces
3. 85 200m
4. 00 Polaris Magnum 325 2x4: stays broke
5. 02 Yamaha Wolverine 350 4x4: trail bike
3. 85 200m
Yes, it does fit.
PRO TIP:
13T XR200 also fits, and is easier to find, but also takes a slightly different bracket that holds the sprocket to the shaft.
One has 2 holes and the other has 3 holes is the only difference.
Thanks that helps a lot. I did find one for the 185s. Just didn't wanna order it and the saver not fit. I'll look into the xr sprockets thanks.
3. 85 200m
//ArrowChat Integreation Code
