Has anyone converted a 81 250R to 82 250R disc brakes? This is for the rear obviously, whats involved? Will I need to change the swingarm? Or is it just an axle swap and buy the hardware needed. Thank you for any help you can!!!!
Taxation Is Theft
Trikes owned
1982 250R
1987 BigRed 250ES (Sold)
1982 Honda ATC 110
Sic Semper Tyrannis
I have an 82R but I'm not sure about your question. You should compare the relevant part numbers on the 81 vs the 82 parts fiche. The swingarms are probably different where the brake mounts. If you're committed to it you can probably find an 82 swinger on ebay.
I swapped on my 81 with little issue. Yes you need a swing arm to an 82, as well as the axle, disc, and brake cylinder. The swing arm and associated parts interchange easy enough. You do have to get a little creative finding a way to mount the brake cylinder and reservoir.
I initially made an adapter plate out of a piece of 1/8 steel. It worked, barely.
Eventually I welded and ground clean stock and on the frame, then drilled and tapped to have the reservoir and cylinder mounted in a more proper fashion.
Regardless of how you do it, take your time and be patient lining everything up with the brake pedal. It makes a world of difference. If it is off, or you don't have enough trvel in the pedal, then it sucks. Then you'll wish you stuck with the drum.
81 250R Custom
83 250R (in progress)
98 Scrambler 400
03 Bombardier Quest 500
07 Polaris Predator (sold to klondike1020 )
68 VW Dune Buggy
This is what I did on mine if you are running a normal size rotor you will not have the same issue I had that I couldn't get the caliper low enough on the rotor with out it hitting the mounting ears for the rotor that's why mine in mounted backwards. The caliper in a pitbike caliper I had laying around and the master is a 300ex and the line I had custom made. I used a small rotor cause I didn't want the rotor to be bigger then the sprocket cause I'm setting this bike up for flat track with kart tires. It's not completely done yet cause I keep putting other sticks in the fire if you know what I mean.
