Results 1 to 11 of 11
Thread: 250sx timing and rotor cap removal
    Jun 2016
    ne ohio
    5
    85 250sx. Need to adjust my valves. How do you get the caps out? Thanks
    6,726
    Remove the two 6mm bolts and pop the cap off . Have at it lol !
    Jun 2016
    ne ohio
    5
    I meant the rotor cap and timing cap on the side case. Not the valve covers. Looks like giant flat head screw driver bolts lol. I honestly skipped finding the t spot and just wiggled the rocker arm while moving the kicker till I felt some play.
    6,726
    If their stuck I use a small punch to tap it loose .
    Another method I use is to remove the spark plug , insert a long screw driver in the plug hole and put the piston at TDC also making sure the cam lobes are pointed down and then your good to adjust the valves .
    125Mmadness's Avatar
    125Mmadness is offline At The Back Of The Pack Arm chair racerFirst time rider
    Apr 2017
    McConnelsville,Oh
    157
    Quote Originally Posted by z13pyz View Post
    there is a certain size washer that fits perfectly in the slot, you can just stick screwdriver through the hole and turn it
    1985 ATC125M: Parts
    1985 ATC200S: 84 200S Bottem end, 200x Head, 200x Carb, S&S Cycle Exhaust, Wiseco 10.25:1 Piston, Reground Cam with About 1mm more lift(unknown specs).
    1988 TRX250X
    1983 ATC200E: Total Pile.
    "Bout Tree Fiddy" Master of Thy 22RE
    May 2009
    S.E. Michigan
    1,250
    If you like buying tools, try this:
    https://www.motionpro.com/product/08-0087
    I have it and it works perfectly.
    - Frank
    1984 200ES Big Red
    1985 350X (x2)
    1986 350X
    1986 250SX
    1984 Auto-X
    1984 ATC70
    1985 ATC70
    Jun 2016
    ne ohio
    5
    Awesome. Thanks wonderboy
    Jun 2016
    ne ohio
    5
    I've run into further issues after valve adjustment. Thought I had them right on the button, for I started it and ran it for a little and heard zero chatter from the top end. Gauged both intake and exhaust at .003". It didn't make any noise till later in the day I started it again and let it idle for about 5 minutes when all of a sudden the top end chatter returned just like that out of nowhere. It's torn back down now, any suggestions?
    6,726
    Probably time for a timing chain .
    Jun 2017
    Phoenix, AZ
    13
    Great shortcut, thanks!
    NEPA
    7,048
    I have a top quality, sharp, cold chisel, she'll tap out anything stripped like it's new. Plug,bolt or nut. I could field strip a whole bike with it and a But only in a pinch. Try it !
